View Full Version : bizhub 250 showing only blue color display
moonwalker3778
11-03-2008, 01:50 PM
Hi experts,
we r facing a prob in bizhub 250.after switch on the machine only blue display is coming.
wat would be the prob? any remedies pls let me know.
Thanks in advance
Sudhakar
minimerlin
11-03-2008, 10:57 PM
Have a look at the contrast adjuster that is down on the right side of the control panel , the slider is normally in the centre of its run. Try moving it up and down to see if the panel contrast changes.
(Just re-read origional post...bizhub 250 does not have control on rh side. sorry! I was thinking of the old Di250!)
The bizhubs contrast control is on the bottom left of the panel
fixthecopier
11-04-2008, 12:03 AM
You may need to rewrite the firmware. If that is not the fix, I would swap the MFB with one from a working machine. That is the board with the card reader and NVRAM.
