View Full Version : Step by step F/W KMB 754
SEESOD TECH
06-03-2020, 01:47 PM
hello,community
i had a problem to firmware KMB 754
because when i connect usb flash drive to device
screen appear error external memory
tell me please,
step by step to firmware konica 754
thank you very much in advance
Synthohol
06-03-2020, 02:25 PM
USB must be no bigger than a 4Gb drive
the correct files and folders must reside on the root of the drive.
use the service port.
escalante
06-03-2020, 02:46 PM
That is the procedure to update the firmware by means of a usb memory457974579845799458004580145802
Enviado desde mi SM-J701M mediante Tapatalk
SEESOD TECH
06-03-2020, 02:47 PM
How important is this F/W version ?
If the model is incorrect Will cause the device to display error external memory screen?
thank you,sir
rrrohan
06-03-2020, 03:00 PM
ive been using 16GB memory for years without problems
Phil B.
06-03-2020, 03:06 PM
thank you,sir
what do you think?
can you put a Chevy v8 in a pinto?
Synthohol
06-03-2020, 03:28 PM
hey Phil, people always find a way LOL...
https://www.copytechnet.com/forums/attachments/konica-minolta/45803d1591194522-step-step-f-w-kmb-754-a-pinto-jpg
Phil B.
06-03-2020, 03:31 PM
https://www.copytechnet.com/forums/attachments/konica-minolta/45803d1591194522-step-step-f-w-kmb-754-a-pinto-jpgOk brother .. bad analogy.
SEESOD TECH
06-03-2020, 03:36 PM
what do you think?
i meant,
we can use latest firmware ver. or use recent fw ver to pcb board
tsbservice
06-03-2020, 03:38 PM
Ha-ha smart one you are :cool:
People ALWAYS will find a ways for crazy things.
tsbservice
06-03-2020, 03:41 PM
i meant,
What sort of problem/s you have? Why do you think it's FW related?
SEESOD TECH
06-03-2020, 03:57 PM
When turn on the device and put usb to service
screen is appear error external memory,
because the firmware incorrect maybe right?
thank you for your replies :)
tsbservice
06-03-2020, 04:06 PM
Follow exactly the steps escalante show you. Also you are supposed first to connect USB and then turn on the machine.
Try it also with front door open.
Albonline
06-04-2020, 12:40 PM
if you are trying to put a used prcb in this , you WILL get that message.
rrrohan
06-04-2020, 01:57 PM
you can tell Life Stop was disabled on that car
emujo2
06-05-2020, 08:13 PM
download HPs USB drive formatting tool. Run this on your USB drive then reoad the files once again. The drive can't have any security software running on it. And some drives work fine for years then they just quit. E
tulintron
06-15-2020, 01:33 PM
[ATTACH] 45921 [/ ATTACH]
