View Full Version : bizhub C308 quality problem
Genotrom
06-08-2020, 02:15 PM
Hi, I have a bizhub c308 with 130k. This printer has started making spots at the bottom of the page. Of course I have to change the black drum but before going, being a restricted area, I wanted some advice from you.thankyou
45835
copier tech
06-08-2020, 02:24 PM
45835
Your image isn't very clear Most likely the black drum. But I would also take a transfer unit with you when you go back.
tsbservice
06-08-2020, 04:11 PM
Hi!
It's definetly the black drum unit. Replace it and it will be okay ;)
Agree, 130k is good counter.
blackcat4866
06-09-2020, 12:36 AM
96 mm interval? Yes, black drum. Typical at 130K or even much less. =^..^=
Walterj
06-09-2020, 04:43 AM
[CITA = Genotrom; 1496274] Hola, tengo una bizhub c308 con 130k. Esta impresora ha comenzado a hacer manchas en la parte inferior de la página. Por supuesto, tengo que cambiar el tambor negro, pero antes de ir, al ser un área restringida, quería que me dieras un consejo. Gracias
[ATTACH] 45835 [/ ATTACH] [/ QUOTE]
Replaces the DRUM UNIT (DR-313K)
Exactly that mistake is due to wear on the drum and black charge roller.
Follow the installation and adjustment steps in the service manual.
Regards.
Hello, often changed the drum and I solved it.
Genotrom
06-09-2020, 03:20 PM
thank you guys!
Yes, I have resolved with DRUM_K
