View Full Version : C3350 Scan to Email
RidleyRumpus
06-08-2020, 06:33 PM
I have just got this unit and am setting it up. Everything else seems to work but I cannot get the Scan to Email to work, when I select it I get "Scan TX Failed"
(Scan to folder works fine) so I assume that I must have some setting set up incorrectly.
The manual indicates that I can set up SMTP etc from the touchscreen but the options do not seem to be there, other than enable or disable, I have to go in via the web interface to reach the options. Is this normal?
Any ideas about what I am doing wrong?
(Does the C3350 have wireless?)
4584345844
tsbservice
06-08-2020, 06:44 PM
You must enable “Less Secure Apps” in gmail settings.
Cantechman
06-08-2020, 07:37 PM
did you put the email address in for the device name as well?
RidleyRumpus
06-08-2020, 07:52 PM
If you mean the account you are sending too, it is already enabled.
wjurls
06-08-2020, 07:53 PM
Use port 587 for gmail. Also as said above, "allow less secure apps" must be set on the gmail account being used. In addition, set the administrator email the same as the authenticating account.
RidleyRumpus
I think that that is in the attachment, does that have to be a "real" email address?
wjurls
06-08-2020, 07:54 PM
He means the account that is being used to sign in and send from.
Synthohol
06-08-2020, 07:58 PM
device email and acct email must match. (yours do not)
also gmail needs NTLM v2.0 IIRC, pic shows v1 (double check this)
set 8.8.8.8 for secondary DNS
let us know
RidleyRumpus
06-08-2020, 08:25 PM
let us know
Added 8.8.8.8 changed device and act email address not sure what to do re NTLM
Still doesnt work.
45845Wish it said more than error in the log :-|
wjurls
06-08-2020, 08:35 PM
Change SMTP port to 587 and select "Start TLS" in the SSL/TLS box. SSL port should then gray out.
wjurls
06-08-2020, 08:46 PM
let us know
Even the very latest KM's seem to show that NTLMv1 box. Never seen it be an issue.
RidleyRumpus
06-08-2020, 10:42 PM
Still doesn't work.
45846
wjurls
06-08-2020, 10:55 PM
The 2 circled items must match. Go to the system page and change the administrator email address to the same account name as the smtp account
45847
bsm2
06-08-2020, 11:16 PM
admin email must be the same as account also turn off pop not needed
Walterj
06-09-2020, 06:25 AM
[CITA = RidleyRumpus; 1496373] Acabo de recibir esta unidad y la estoy configurando. Todo lo demás parece funcionar, pero no puedo hacer que Escanear a correo electrónico funcione, cuando lo selecciono aparece "Escaneo de TX fallido"
(Escanear a carpeta funciona bien), así que asumo que debo tener alguna configuración configurada incorrectamente.
El manual indica que puedo configurar SMTP, etc. desde la pantalla táctil, pero las opciones no parecen estar allí, aparte de habilitar o deshabilitar, tengo que ingresar a través de la interfaz web para acceder a las opciones. ¿Esto es normal?
¿Alguna idea sobre lo que estoy haciendo mal?
(¿El C3350 tiene conexión inalámbrica?)
4584345844[/ QUOTE]
Good day:
To perform scans via email.
Perform a Restore All from Admin Mode> Security> Security Detail> Initialize, and a
HDD Format. Make sure the machine has the latest firmware. The latest version of firmware
bizhubC3850Series Cont_A3GN30G0851-899
bizhubC3850Series Cont_A3GN30G0851-W99
Any questions you can write to my email walvaradocruz@gmail.com
Regards.
copier tech
06-09-2020, 09:46 AM
4584345844
You'll need to be on later firmware for gmail to work this applies on most Bizhubs engineers are lazy & don't routinely update.
Set the device email address to c3350seed@gmail.com send a scan again now log into your gmail account c3350seed@gmail.com & can you see any security issue messages?
You may want to hide your email as you did with the password..
Ryaren
11-03-2021, 01:40 AM
Hello!
I managed to set it up.
smtp.gmail.com
port number: 587
Start TLS
port number: 587
Administrator e-mail: whatever@test.com
Device e-mail: whatever@test.com
Account: yourgmailaddress@gmail.com
No need for NTLM v2, it works for me with NTLM v1! :)
Remus2k
03-31-2022, 09:45 AM
I have a Bizhub C35 that was working with those settings:
52792
The printer died and I received a Bizhub C3350 that using the same settings, I get Tx scan error!
Do I need to change the firmware?
ROM Version
Controller ROM VersionA3GN30G0803-W99
Engine ROM VersionA3GN0Y00050G001900
Boot ROM VersionA3GN99G0100-999
Panel ROM VersionA3GN02G0152-999
Scanner ROM VersionA3GN23G0102-999
Fax Board ROM VersionA6ED40G1201-999
Remus2k
03-31-2022, 10:00 AM
Succes!
See the attched file with settings.
1. Enable Less Secure Apps in your gmail account
2. Create 2FA Auth
3. Create App Password for your printer
4. Put DNS settings 8.8.8.8 and 1.1.1.1
I also use my own router as DNS
Use those settings
5279552794
