View Full Version : C300i - Color Cast on Scans
mkonkelz
06-12-2020, 04:42 PM
Hi everyone,
i have a problem withy my scans having a magenta color cast. This behavior occurs randomly, maybe once out of 10 scans.
The whole document will have the color cast, it doesn`t matter how many pages, or which settings (resolution e.g.)
I attached two PDFs with one having the cast and one scanned normally as it should be:
45906
45905
Scanner: DF-714 DualScan
Firmware: AA2J0Y0-0100-G00-7B(00) - Function Version: 1.0
Settings are alle pretty much standard. No additional software installed.
qbert69
06-12-2020, 04:49 PM
Hi everyone,
45906
45905
Settings are alle pretty much standard. No additional software installed.Are your scan settings configured for strictly B&W or Auto Color Detection???[emoji848]
Sent from my SM-N950U1 using Tapatalk
copier addict
06-12-2020, 04:50 PM
Hi everyone,
45906
45905
If you are duplex scanning does it show on side two?
mkonkelz
06-12-2020, 04:52 PM
I always scan using auto color detection, so it shows on auto color. I don`t scan B&W.
mkonkelz
I need to try this. The scans so far were only one sided.
Edit: It also appers on the original glass.
Cyclops85
06-12-2020, 04:54 PM
Possible CIS asssembly or cable
qbert69
06-12-2020, 04:55 PM
I always scan using auto color detection, so it shows on auto color. I don`t scan B&W.There ya go!!! Sounds like it is flip-flopping between b&w and color during auto detect...set to strictly b&w and see what kind of results you get!!! [emoji41][emoji1303]
qbert69
06-12-2020, 04:58 PM
I always scan using auto color detection, so it shows on auto color. I don`t scan B&W.Possibly a "white balance" calibration issue during auto color/b&w detect. There should be a way to adjust the sensitivity!!![emoji41][emoji1303]
Cyclops85
06-12-2020, 04:59 PM
I highly doubt that is a setting issue. It looks like CIS assembly or cable. We used to see this occasionally on the 8 series.
mkonkelz
06-12-2020, 05:00 PM
Okay, i just tried scanning double sided. And it only shows on the 1st side(s).
So the DualScan CIS seems not to be affected.
Edit: Also it just appered on 4 separate scans in a row, just to disapper on the 5th one, without changing anything or moving the DualScanner.
Cyclops85
06-12-2020, 05:05 PM
What about from the platen?
mkonkelz
06-12-2020, 05:09 PM
It appears from the Platen and the DF.
When scanning 2-sided from the DF it`s only on the 1st page.
When disabling Auto-Color and scanning B&W only the problem seems to disappear (not sure yet).
Sometimes it`s up to 4-5 scan jobs in a row. Sometimes everything seems normal.
Cyclops85
06-12-2020, 05:15 PM
Possible CCD or MFP board. Is the machine brand new? There is a security measure - press stop,1,1,4,4,C in service mode and you need to input the correct date and time at install. Sometimes if this step is missed it will give coloured backgrounding or lines through copies. Have you done this procedure?
qbert69
06-12-2020, 05:20 PM
Sometimes it`s up to 4-5 scan jobs in a row. Sometimes everything seems normal.See if there is a setting to change auto color detection sensitivity!!! I have used other scanners, not just KM that when B&W is scanned in color, there will be a slight magenta cast which is related to the green sensor array in the CCD array!!! Make sure your glass & white balance strip are CLEAN!!! Check your auto detection sensitivity!!![emoji41][emoji1303]
mkonkelz
It is brand new (1 week old).
I will try it out, but the system got set up by the dealer (it had the right date and time configured on delivery).
mkonkelz
06-12-2020, 05:21 PM
Glass and strip are clean. I will search for an auto detection sensitivity setting and check it.
Edit: I am scanning color in color. It also appers on a scans with pictures and vibrant colors.
qbert69
06-12-2020, 05:22 PM
Glass and strip are clean. I will search for an auto detection sensitivity setting and check it.Check the easy stuff before you start replacing parts!!![emoji41][emoji1303]
Albonline
06-12-2020, 06:30 PM
you paid for a working unit, get the dealer to fix this!
qbert69
06-12-2020, 06:43 PM
I will try it out, but the system got set up by the dealer (it had the right date and time configured on delivery).I'd be curious to see what the internal color test page looks like directly from the engine!!![emoji848]
mkonkelz
06-12-2020, 06:51 PM
Prints look fine, and also the test printouts from the service menu for color adjustment look great.
What test page do you mean?
qbert69
06-12-2020, 06:58 PM
What test page do you mean?Ok. Just making sure! Sometimes if D-Min & D-Max are not calibrated correctly, you can have weird things happen!!![emoji41][emoji1303]
Albonline
06-12-2020, 07:01 PM
this is a color detection issue, do the calibration adjustments if it still persists, most probably poor connection in the ccd circuit, could be ccd optical alignment, bent scanner, misaligned/loose dislodged mirror.
qbert69
06-12-2020, 07:09 PM
this is a color detection issue, do the calibration adjustments if it still persists, most probably poor connection in the ccd circuit, could be ccd optical alignment, bent scanner, misaligned/loose dislodged mirror.Think Simple...B&W/Color Auto-detect threshold. Magenta background related to the green sensor in the CCD. I believe he said the magenta toning of the background was consistent across the page![emoji41][emoji1303] Remember!!! He SAID *AUTO-DETECT* was TURNED ON for SCANNING!!!
qbert69
06-12-2020, 07:22 PM
IF the paper you are scanning contains "Optical Brighteners" (additives to make the paper whiter/brighter, mostly towards the blue spectrum, sometimes fluoresing to some degree under a particular light source!!!) it's possible that with the scanner, it is picking up this reflective color cast and (mis)interpreting it as having a "background". In the case of LED's as a light source the color cast they exhibit is called "binning"...
A Look at the Past and Future of LED Binning - Lumenpulse (https://www.lumenpulse.com/knowledge/led-binning)
mkonkelz
06-12-2020, 07:40 PM
The problem occurs with different papers. Also when scanning recycling paper and newspapers for example.
qbert69
06-12-2020, 07:46 PM
The problem occurs with different papers. Also when scanning recycling paper and newspapers for example.Make a preset for newspapers with the bleed thru removal detect turned on!!! It's under the scanning application choices and should be listed as "Bkgd. Removal" or "Bleed Removal"...you will be able to adjust the amount of background removal!!!
https://uploads.tapatalk-cdn.com/20200612/416f616c29a39f426a2d4433e1781832.jpg
mkonkelz
06-12-2020, 07:52 PM
I have tried it with bleed removal and discoloration adjustment both turned off and on. It`s still the same.
My standard setting for both would be "off" / 0 Standard.
qbert69
06-12-2020, 07:54 PM
My standard setting for both would be "off" / 0 Standard.Have you selected and been using the "bleed removal" when scanning newspapers???[emoji848]
qbert69
06-12-2020, 08:00 PM
My standard setting for both would be "off" / 0 Standard.Just sent you a PM so you can send me a sample via e-mail!!![emoji41][emoji1303]
mkonkelz
06-12-2020, 08:14 PM
Normally i don`t use bleed removal, but for test purposes on this i did, and nothing changed.
qbert69
06-12-2020, 08:20 PM
Normally i don`t use bleed removal, but for test purposes on this i did, and nothing changed.YIKES!!!...all MAGENTA?! ...were you trying to do a color substitution/color replacement test??? Looks like the M component of a C-M-Y Separation!!!...but you're just scanning and not printing?![emoji848]
mkonkelz
06-12-2020, 08:37 PM
Yes, printing is all fine. It only appears on scans.
qbert69
06-12-2020, 08:40 PM
Normally i don`t use bleed removal, but for test purposes on this i did, and nothing changed.Color cast scanned image is showing a heavy magenta component where there should be none!!! The only "real" color components in the scan should be Red, Green & Blue, since the CMY is not introduced into the equation until print processing!!!
tsbservice
06-12-2020, 08:43 PM
Hi everyone,
45906
45905
7B firmware should be at Function Version: 2.0
I would try later special FW just for a good measure.
Strange problem. Don't think you can resolve it yourself even with great advices from techs here especially so intermittent and from both DF and glass. Claim it to KM dealership. Let us know.
Good luck.
qbert69
06-12-2020, 08:46 PM
Good luck.Were you able to get a sample from him? He just sent me one & it looks like a color substitution/ replacement!!![emoji15]
https://uploads.tapatalk-cdn.com/20200612/c17506025e163647ec5a596aa69b82f5.jpg
mkonkelz
06-12-2020, 08:52 PM
I attached the sample to Post #1 :)
qbert69
06-12-2020, 08:53 PM
Sent from my SM-N950U1 using TapatalkGreen is the direct complement of magenta...direct opposite on the color wheel....green ccd component missing...not being processed!!![emoji848][emoji15]
mkonkelz
06-12-2020, 08:54 PM
Good luck.
Would be great if someone could provide me a newer firmware to install.
When i can`t solve the problem i`ll call the KM dealer.
I think the chances are pretty high, that this is a software problem? No?
qbert69
06-12-2020, 08:55 PM
I would check & re-seat all electrical connectors pertaining to the scanner connection!...that is, if you're a tech! Otherwise call a local tech![emoji41][emoji1303]
qbert69
06-12-2020, 08:57 PM
Get a local tech involved or the dealer it was purchased from!!![emoji41][emoji1303]
mkonkelz
06-12-2020, 09:12 PM
I am a trained tech, but that was a while ago. Nowadays i do a different job, but still maintaining my printers and MFPs by myself.
But if this boils down to be a hardware issue i`ll sure call the dealer. I thought this might be a known problem.
tsbservice
06-12-2020, 09:13 PM
At this point my recommendation is leave it to dealer.
If you persist to attempt something maybe try FW in case of data corrupted.
For easy start change sw25 in system 2 to 10 equal function version 2.0 and reboot. I could help with FW monday.
Don't disassemble anything for now possible warranty voids etc. Any parts replacement must be at dealership expenses so they will want to troubleshoot/test/resolve it by their techs not you(customer).
