View Full Version : Konica Minolta Bizhub C364e Airprint
Alex1
06-13-2020, 04:21 PM
Hi all, I have a Konica Minolta Bizhub C364e and I want to activate Airprint on it. I have the latest firmware to install but is there a soft switch setting I need to change in service mode? Does anyone know what the setting is as I can't remember it.
copier addict
06-13-2020, 04:35 PM
If I remember correctly, once the firmware is installed you just need to go into admin and then network and enable airprint
tsbservice
06-13-2020, 05:00 PM
Link sent.
Bix
06-15-2020, 09:51 AM
Correct, if you downloaded the latest firmware you must enable AirPrint from the network settings.
copier tech
06-15-2020, 10:28 AM
Change the function version to 7
CE mode system 2 SW25 HEX 60.
Then enable AirPrint in admin>Network settings.
Alex1
06-19-2020, 12:16 PM
After I done thus I can not log in to the machines interface nor can I scan to email. I changed the hex settings to 50 for SW25 rather then 60 does this effect it in anyway
Synthohol
06-19-2020, 12:30 PM
60 not 70, not 50.
Alex1
06-19-2020, 12:51 PM
60 not 70, not 50.
Sorry I meant 60. I'll try it again.
Synthohol
06-19-2020, 01:12 PM
what model shows on top of a printed network configuration page?
Alex1
06-19-2020, 01:32 PM
I'm doing this remotely so I am unable to print out the sheet. But it worked it logged in thanks for the help.
