View Full Version : Error Code bizhub 951 error code c-0104
naeem334
06-16-2020, 03:25 PM
Hay , after press the print button vertical conveying motor M8 just run for 1 second only and code 0104 appear .
wjurls
06-16-2020, 04:22 PM
Either a failed M8 motor, failed Printer Control Board, or the wiring in between.
GVeliz
06-16-2020, 07:55 PM
1. Check the connector connection and the wiring between PRCB and the motor, and repair it if any abnormality. 2. Check the I/O drive of the motor and the coupling of the gear, repair/replace it if any abnormality, and then replace the PRCB (Wiring diagram: Main body (3/4): 6-I). 3. Replace M8 and PRCB at a time.
Did you find the cause of the problem?
Phil B.
05-06-2021, 04:23 AM
Did you find the cause of the problem?Did you read the thread?
No solution yet
Thread started in 2016
Last comment 2020.. so I'd say no unless they didn't come back with an update, which is common for most folks.
