fatduke
06-24-2020, 08:08 AM
Hi everyone!
I would like to share with you this fix for C454 (series)
I had paper jam from cassette 1. When paper starts its path, paper jam incoming with a little loud noise.
All stopped.
I removed 1st paper feed section, looked all the gears, bushes, guides and so on and then I found the problem!
Attached the pic showing that pointed sensor wasn't in is correct place!
But this is a fix, a lot of times are paper feed roller, bushes and gears instead, solenoid etc.
This is only one solution.
I hope I was helpful!
Cheers
All stopped.
Cheers
