View Full Version : C454e air print function
May i know how to enable air print function , i upgrade firmware to A5C10Y0-F000-G20-M1 still can't found ( missing ) to on it .
copyman
06-27-2020, 02:50 AM
These older models were not the best for mobile printing. See attached. Hopefully there is something in there that may help you.
thanks for sharing . But my issue is no button to on this function at adminstrator- network setting - air print
copier tech
06-27-2020, 12:07 PM
After you have updated the firmware you need to enable function version 7.
In CE mode System 2 > Software Switch Setting>Switch 25 set to HEX 60.
Reboot then you will have the AirPrint option in admin mode. (its off by default)
46029
46029
yes i follow the step ,but still no air print function at page two . now i blur.....
copier tech
06-29-2020, 10:29 AM
There are two other SW that may need to be changed.
I would also update to the latest firmware version GDN-M1
46039
46039
thanks for sharing , i will try and update soon ...
Yes is work .Thanks so much ;)
copier tech
07-01-2020, 10:01 AM
Great! thanks for the feedback!
