Boltaction
06-30-2020, 04:39 PM
Hey everyone,
I am having a color issue with a Konica Minolta C552. This print job will run great and then from one page to the next, the colors change almost as if the yellow is overcharged, or cyan goes missing. It is consistently inconsistent as it can run 9 out of 10 fine, or 9 of the next 10 will be off. Sometimes it is one page, sometimes it is five in a row.
Re-seated everything on the HVPS, re-seated transfer belt and all imaging units, even created a spacer to hold the IU's tighter against the contacts on the machine side, cleaned contacts, ID sensors, ran gradation adjustments. Customer also has a C654e that I have tested the job on and it runs great. I've tested the job on two different Macs and even tried using the C654e driver on the C552 and none of it made any difference. I had the exact problem at the same account about a year ago on the same machine but they ended up just running the job on the C654e and called it good. This job is run on plain paper setting but the stock is a little bit glossy.
At this point I would say it's something within the file or InDesign, but why doesn't it do it on the C654e?
I've attached the example, the second page is the problem image. Let me know what you guys think!
