View Full Version : Cover DF-704 difficulty in disassembly
Genotrom
07-08-2020, 12:07 PM
This is quite embarrassing but I was unable to remove the cover over the rollers.
The printer indicated a jam but I was unable to find anything. So I wanted to see if something was hidden under them. I seem to remove all the screws but it remains stuck.It is not like simple DF, I have removed the screws but some I cannot find them. The images do not correspond to what I saw
46129
Any advice on how to disassemble that cover?
I solved the problem by moving the DF, maybe some sensor had blocked. But I'm upset about not being able to remove that cover.
copier tech
07-08-2020, 12:58 PM
46129
There is about 10 screws on this cover, all black, some are hard to see I always forget one when taking this cover off!
Once the cover is off give this area a vac or blow out I also remove the sensors give them a proper clean & refit.
Also replace the friction roller ass'y is all needed I clean the pick up & feed.
Genotrom
07-08-2020, 01:36 PM
In DF-701 it is much easier to identify them but here I really struggle. I could not locate those circled in red. Unfortunately I was in a hurry from the client, so I didn't see much. Maybe I have to remove some other covers?
copier addict
07-08-2020, 02:02 PM
Does the cover feel loose?
Genotrom
07-08-2020, 03:42 PM
It remains completely blocked. I don't understand if it is blocked by the document feed tray. I keep it relieved but it shows no sign of moving.
copier tech
07-08-2020, 04:07 PM
Did you follow the service manual? a few other parts have to come off first.
46137
Genotrom
07-08-2020, 04:28 PM
46137
Thank you! So for the Lower Guide assembly it is necessary to disassemble the Front Cover and Rear Cover. In the other df it is not necessary, that's why I was foolish.
copier tech
07-08-2020, 09:14 PM
Yes the DF-629 reverse feeder is easier to work on.
setfree40
06-29-2021, 08:00 PM
Hope you don't mind me asking, and I know this is an old post, but what issue were you having to need to remove the cover?
srvctec
06-29-2021, 08:15 PM
Did you read the first post? According to it, there was a jam.
