View Full Version : Consumable life reminder b287
blinxwap
07-10-2020, 05:21 AM
I have already changed life stop setting in service mode and turn off all reminders , also cleared counters but it still displays druk unit k needs to be replaced mc drum is still good 100k copies is there a software switch to turn off life reminder or any setting i have missed for the b287..
Sent from my SM-A505F using Tapatalk
truongxuananh
07-10-2020, 07:00 AM
if you want , you change new chip on drum unit ( only chip, it is ok )
blinxwap
07-10-2020, 07:09 AM
Ill do that
Bix
07-10-2020, 11:25 AM
Messages already present cannot be deleted after making the change. So the chip solution can help you.
copier tech
07-10-2020, 11:46 AM
Don't waste your money on the chips!
Did you check SW 51 & 55 are set correctly? F0 0C etc.
blinxwap
07-10-2020, 12:40 PM
No not yet will check
