View Full Version : C1100. C3103
big jase
07-10-2020, 07:48 AM
C1100. C3103 code. 2nd transfer not lifting
Checked all gears cleaned sensors no joy. Just codes up straight away. Any PPD guys out there who could point me in the right direction
Was getting C3104 originally cleared that as swing plate was locked
big jase
07-13-2020, 09:06 AM
Hi what is the model?
The model is C1100
Toxic
07-13-2020, 10:05 AM
Did you try I/O check mode 24-1 - 24-3 ?
big jase
07-13-2020, 11:00 AM
Yes but get code on closing doors , get no drive.
Toxic
07-13-2020, 12:08 PM
I would first check if drive is not blocked.
Can you disengage motor from drive (let it rotate freely ) and then try I/O check again.
Never tried this but it should be possible to do.
If you get error again i would try replace motor first
lucky13
07-24-2020, 06:23 PM
like what toxic said i/o ps53 24-1 with door open and adu rolled out do not press start button and manually flag ps53 does should show 000 non pressure then flag it and see if goes 001 pressure.
khattab.al.masry
08-04-2022, 12:48 PM
Do you hear any noise?
