Synaux
07-16-2020, 02:19 AM
Hi, I have two Questions of curiosity:
"11.14.6 Original Size Detection
Copy Glass
(a) Use
• To change the size detection table for the document glass.
(b) Default setting
• The default setting varies depending on the marketing area.
(c) Setting item
• 'Table1'
• Table2"
Ok that is nice, but what is Table 2 for? There does not appear to be any further elaboration. There is a bulletin: "Detecting A4 and Letter size original from the glass" KBA00028946 which is also sufficiently vague.
"ADF Size Detection
(a) Use
• To set whether or not to give a priority to the detection of 8K/16K size when DF is used.
(b) Default setting
• K Size
(c) Setting item
• 'K Size'
• B series"
I assumed "B series" is the ISO standard, but doesn't make sense being in the US. And perhaps I am crazy, but I have never heard of a K size paper type. I just want to be able to understand what these two items actually mean.
Anyways, this machine was cutting off copies (when not using auto tray) and scans. Changing it to the default "K size" seems to have fixed the issue. The scans were particularly insidious as the screen does not show what the machine thinks the paper size is (as far as I can tell). Therefore, the user cannot determine if the scan is garbage until opening the scan.
Also (not huge concern), I cannot seem to find an option to make custom scan file names like on the older models??
Copy Glass
(a) Use
(b) Default setting
(c) Setting item
• 'Table1'
• Table2"
"ADF Size Detection
(a) Use
(b) Default setting
• K Size
(c) Setting item
• 'K Size'
• B series"
