orestesp
07-19-2020, 07:50 AM
Hello,
Something happened the other day that had me confused. I printed a couple of sheets on the C6500, made some changes to the job, and then quite literally after 10 minutes when I went to re-submit job with the changes I made this happens... The black drum for some reason started picking up excess toner and soiling the entire background with it. The first thing I did was throw in a new K drum and the problem immediately stopped. I went ahead and printed a couple of hundred sheets after that with no problem at all.
Machine counter is 3M. New coronas, K drum and dev almost at their EOL. The cleaning blade isn't to blame, it was the first thing I checked.
I've attached a picture of the drum, where you can clearly see what happened (I have also removed some details from the printed job, but it shouldn't matter as you can still see what's going on). Sorry for not attaching a picture of the printed sheet, I had totally forgot about taking a picture of it.
Thanks.
Thanks.
