View Full Version : bizhub 600 boot not completing
manzoorwighio
07-21-2020, 08:03 AM
https://www.youtube.com/watch?v=cQaVrP3Qmck
Toxic
07-21-2020, 11:01 AM
Does scanner lamp turn on during booting?
I think it should be turn on,if not check scanner lamp,inverter board...?
manzoorwighio
07-21-2020, 12:27 PM
When Scanner lamp turn on boot complete . But when doesn't turn on not boot compelete
Synthohol
07-21-2020, 01:37 PM
that model is at least 14 years old. the battery must be shot by now?
Toxic
07-21-2020, 02:05 PM
There is your solution,i would try replace lamp first.
Have same problem on other newer model and it was faulty lamp.
tulintron
07-21-2020, 02:45 PM
Try to update the firmware on the card. I've solved problems like this one by updating
femaster
07-21-2020, 11:38 PM
Updating, or just re-flashing it. We very frequently had issues with the CF cards getting corrupt in these.
MarioTech
07-21-2020, 11:55 PM
The lamp should turn on to read the white pattern when it's under the slit glass, I don't see that happening but before you even order a lamp as I read on other posts flash the firmware. That should help with the freezing up issue, once you try that then follow next problem.
