View Full Version : Bizhub C552, HELP ME
potro_salvaje
08-03-2020, 03:03 PM
Hi guys, i have that line that comes out on the side of thesheet, sometimes it is cyan, sometimes magenta, I already changed drum/dev,of the 3 colors and nothing, any suggestion.
46400
barber782
08-03-2020, 03:11 PM
What orientation is the paper going? As it could be transfer if its landscape
Sent from my VTR-L09 using Tapatalk
copier tech
08-03-2020, 03:19 PM
46400
This is caused by the transfer unit.
Most likely the image & dev units were ok.
potro_salvaje
It is horizontally oriented, from Tray 1
Synthohol
Agreed. Looks like t-belt is not cleaning itself.
potro_salvaje
08-03-2020, 03:36 PM
U mean the transfer belt bias?
Phil B.
08-03-2020, 03:45 PM
no the rubber transfer belt not internal settings the mechanical component
barber782
08-03-2020, 09:14 PM
If you take out the transfer unit there might be a small shard of paper of fluff stuck in the cleaning unit. Or the belt is just worn. I sometimes take apart the itb cleaning assembly and clean it out just in case anything has become lodged in there. And if you can clean and redust the blade with some powder lubricate or yellow toner. And after that run 15 pages of yellow halftone prints to lubricate the belt.
