View Full Version : Need help with a 552 DF part number
SAR
08-05-2020, 05:34 PM
46422 For some reason I can't find this part in the KM parts manual. If you raise the feeder up, it's the foam guide in the conveyance section (see arrow pointing at part). The foam has rotted out and it is falling apart. This is from a Bizhub 552 DF. I'm not sure if you can get by without this piece, but the tech having the issue said it is skewing without the foam guide.
Thanks!
Synthohol
08-05-2020, 06:10 PM
Which feeder? Df-xxx
Albonline
08-05-2020, 08:21 PM
It's a DF-617.
should be a 618 i think
Albonline
08-05-2020, 08:30 PM
A0HT260400 Guide, i think that is what you want.
SAR
08-05-2020, 09:24 PM
Thanks Albonline, i'll give that a try. The DF came mounted on the 552 series from the factory, so the DF parts are in the copier parts manual. I tried to find a DF-618 manual on the KM site, but no luck.
Synthohol
08-05-2020, 10:44 PM
yeah, the feeder is included in the copier parts manual.
also i wonder if that guide comes with the white piece?
its shaped like a fat "T" but the manual only shows a strip.
here is what albonline listed.
https://www.copytechnet.com/forums/attachments/konica-minolta/46426d1596663853-need-help-552-df-part-number-12-jpg
SAR
08-19-2020, 01:44 PM
46537Just got the part in and wanted to confirm that A0HT260400 Guide is the correct part. I guess KM was just too lazy to draw it correctly in the parts manual. Thanks again for the replies!
