View Full Version : bizhub C654e black screen
escalante
08-11-2020, 04:38 AM
When the equipment arrived in our office in December, it turned on and worked perfectly. And it was off for about three months. And when he came back, the team didn't turn on the panel. That in black, the power button in pink.https://uploads.tapatalk-cdn.com/20200811/ca179a78dd64afa9c566159fa135ba39.jpghttps://uploads.tapatalk-cdn.com/20200811/c2ed87edfb9a7d4d80135eaab77bfe62.jpg
Enviado desde mi SM-J701M mediante Tapatalk
zoool
08-11-2020, 07:54 AM
You can have trouble with dimm memory in mfpb. change it on working one
escalante
08-11-2020, 12:54 PM
i can have trouble with dimm memory in mfpb. change it on working oneThe steps you take
Step 1
disconnect and replace Memory board/1 (MEMB/1).
Step 2
Disconnect the connector
Dual scan image processing board (DSIPB)
Step 3
Disconnect the HDD
If you have another suggestion, it will be well received.
copyman
08-11-2020, 01:25 PM
If you hear machine go through normal warm up cycle try and log onto copiers web interface page. If you can get onto that page the control panel is most likely bad. If not try loading firmware.
