View Full Version : Error Code Bizhub Pro C1070 error code C-2214
madmom
08-17-2020, 09:57 PM
Hi guys,
does anyone have any idea how to resolve a C-2214 error code on a Bizhub Pro C1070?
Everything started with a black color shift, a jam and a C-2214 code, I restarted the machine and restarted the printing, two sheets was good then the same problem: Black color shift, jam and C-2214. After that the error code appears on start-up.
I cleaned everything: coronna, gamma plate, drums, belt gears ... In short, everything that is visible. Via the i /o Check mode the 4 front motors are working correctly, so I have dismantled the rear machine and checked the 4 encoders and they look good.
The machine has 1.600,000 prints.
Thanks in advance.
Phil B.
08-17-2020, 10:08 PM
Hi guys,
Thanks in advance.
are you a trained tech? looking at your sparse info on your profile it's hard to tell if you are a tech or just an end user.. if it is the latter I would venture a guess this is above your paygrade.
just because something 'looks' good doesn't mean the sensors is working properly.. did you test them in Service mode?
madmom
08-18-2020, 08:42 AM
Hi Phil,
I am just a simple end user, by the way, I'm self taught and have been working with a Bizhub Pro C6500 for over 10 years and doing all maintenance and repairs by myself, admittedly it takes me longer time than a qualified technician to do it, But I'm doing it very well
the BizhubPro 1070 is a new used acquisition
Thank you for your contribution.
robinsonad86
08-18-2020, 09:01 AM
Hi Phil,
I am just a simple end user, by the way, I'm self taught and have been working with a Bizhub Pro C6500 for over 10 years and doing all maintenance and repairs by myself, admittedly it takes me longer time than a qualified technician to do it, But I'm doing it very well ��
the BizhubPro 1070 is a new used acquisition ����
Hi Madmom
I am trained on these machines just a word of caution, these PPD machines are not the machines you want to be doing guess work on. You say its a new used acquisition my advice would be go back to the company you brought it off. Failing that depending on location I would be happy to offer my services
robinsonad86
08-18-2020, 09:03 AM
If its any help to you in the service manual 2214 is listed as a "drum motor abnormality" on black
tulintron
08-18-2020, 01:38 PM
Hi guys,
Thanks in advance.Have you done any maintenance on the transfer unit in this equipment?
I am thinking about a defect, because it is an end user with little maintenance knowledge
madmom
08-18-2020, 02:50 PM
Hi Tulintron,
The maintenance was done more than two months ago and the machine has already performed more than 35,000 prints since.
