View Full Version : Copy Program Button Missing on Bizhub C300i
captainrva
08-27-2020, 03:17 PM
I've got a Bizhub C300i and the Copy Program button is just missing from the copy screen. I'm looking everywhere to find an enable/disable but I'm having no luck.
46639
copier tech
08-27-2020, 05:55 PM
46639
There were/still are a few bugs with the new i series.
Most were resolved with a firmware update.
Synthohol
08-27-2020, 06:31 PM
Blindly guessing here without checking the knowledge base, is the HDD enabled?
tsbservice
08-27-2020, 06:39 PM
There's a tool to edit panel buttons can't remember name right now. Also make sure it's on B5 latest FW as others mentioned it won't hurt for sure.
Edit: panel customize tool I believe is the name
bsm2
08-27-2020, 06:44 PM
Not sure if this works for your model
think you'll have the option in there
good luck
https://youtu.be/HwX62rKDdmQ
https://www.youtube.com/watch?v=e9FOQYqoack
drowranger
08-27-2020, 11:00 PM
Like others said make sure you are running on function version 2 firmware.
Please check [Administrator] > [SystemSettings]➔[Change Permission for Default Value]➔[ON]➔[OK] is set as well.
tsbservice
08-28-2020, 07:38 AM
Good call but I believe this is applied to Basic style and his problem is with Classic style copy screen.
