View Full Version : Miscellaneous Import/Export address book from C308 to C300i
copier tech
09-18-2020, 07:36 PM
Quick question, i'm upgrading my client with a C308 to a new C300i so is it possible to transfer the address book?
Don't think I've tried, i'd like to use the USB method.
Leyahné
09-18-2020, 07:41 PM
You need to set the soft switch in service mode and then in admin mode transfer to export to USB
Sent from my SM-N960F using Tapatalk
emujo2
09-18-2020, 07:43 PM
Page Scope Data Admin will do the same..Pretty handy tool as long as you keep it updated. E
copier tech
09-18-2020, 07:46 PM
Yeah SW72 HEX 04.
I believe on the 8 series this is set by default.
Leyahné
09-18-2020, 07:49 PM
Use thishttps://uploads.tapatalk-cdn.com/20200918/1ab27ccd2073bf937ab67f26989a2e0f.jpg
srvctec
09-18-2020, 09:21 PM
I've had the USB method not work sometimes so I usually just use Pagescope Data Admin. I just imported all access codes/accounts and one-touches from a C220 (no USB backup option) to a C550i using PDA the other day. Worked like a charm.
copier tech
09-19-2020, 10:24 AM
Thanks thats good to know!
mascan42
09-20-2020, 02:19 AM
Address book works fine, but don't try to do network settings or anything like that by USB. The i series stores that data differently, and I've seen machines lock up because it doesn't recognize the data.
copier tech
09-21-2020, 07:58 AM
The menu layout is different on the i series, but is the import section in the same place?
copier tech
09-21-2020, 08:00 PM
Import/export worked fine via Pagescope which was a bit help as there were around 50 SMB entries this saved me a lot of time!
