View Full Version : Bizhub C220 Setup
DM2-Inc
09-21-2020, 03:43 AM
I purchased a Konica Minolta Bizhub C220 from a company closing it's doors due to COVID.
I'm an end-user, not a technician, but I setup network systems, so believe I can handle some of what I need to do to get this copier working.
I've set it up in my home office, because now I'm working from Home due to COVID, and thank full I still have a job.
The unit has:
DF-617 Reverse Automatic Document Feeder
EK-604 Local Interface Kit
PC-207 Paper Feed Cabinet
SD-509 Saddle Sticher
FS-527 Finisher
PK-517 Punch Kit
JS-603 Job Separator
Question:
I've seen several "Installation" sheets, on this web site, that have 10 to 20 pages to them. These appear to be for initial setup of the printer. I've downloaded some 20 manuals from Konica Minolta's web site, and have Parts manual and Service manual. Are there individual Installation sheets for the various above parts that I should be looking for?
The Paper Feed Cabinet has 11 x 17 paper in Tray 3, but every time I print, It always says it's A3 paper. I thought I set this up using the printers web interface, but I always have to override this when I print. I've looked for a manual on the control panel and how to use it, but Can't find one...How do I set this up?
Thanks in Advance
Dan Marr
bsm2
09-21-2020, 04:01 AM
The unit has:
FS-527 Finisher
PK-517 Punch Kit
Question:
Thanks in Advance
Dan Marr
Print driver should be pcl6 Not the Universal driver and select the c220 it should add any features
2nd check the paper tray guides the most common problem you can manually set the paper tray to 11 by 17 under the paper tray setting on the operational panel user settings
copyman
09-21-2020, 04:02 AM
The unit has:
FS-527 Finisher
PK-517 Punch Kit
Question:
The Paper Feed Cabinet has 11 x 17 paper in Tray 3, but every time I print, It always says it's A3 paper. I thought I set this up using the printers web interface, but I always have to override this when I print. I've looked for a manual on the control panel and how to use it, but Can't find one...How do I set this up? You are correct have to change paper tray to 11x17 at copier control panel, "touch auto paper",select tray 3, "change setting", 11x17
Thanks in Advance
Dan Marr
Not sure how you were able to get into the dealer side of Kon/Min and get the service and parts manuals but good to have for codes, etc.
There are many "user" manuals on the regular Kon/Min website. The service manuals don't get into using the machine, user settings, control panel buttons, etc. You will find all of this in the operators & advanced operator manuals.
That is a good machine so should work well for you.
Best of luck with it.
DM2-Inc
09-21-2020, 04:34 AM
Copyman
The service manual I have is version 1.0, and is dated 2009.07, so it might be a bit dated, but it should have what I need.
As far as the manuals go, what I have is below, but I don't have one titled "...operators & advanced operator manuals..." You don't have a link to it do you?
The numbers are simply the order they appeared on the Web site...
Konica Minolta 01 - Driver Packaging Utility User's Guide
Konica Minolta 02 - HDD Backup Utility User's Guide
Konica Minolta 03 - Bizhub C360, C280, C220 Log Management Utility User Guide
Konica Minolta 04 - User's Guide - License Install Utility
Konica Minolta 05 - User's Guide - Setup Utility for Right Fax
Konica Minolta 06 - Device Set-up User's Guide
Konica Minolta 07 - Bizhub C360, C280, C220 User's Series PKI Security Operations
Konica Minolta 08 - Bizhub C360, C280, C220 User's Guide AU-211 Authentication
Konica Minolta 09 - Bizhub C360, C280, C220 User's Guide AU-201H
Konica Minolta 10 - Bizhub C360, C280, C220 User's Guide MS Office SharePoint Server 2007
Konica Minolta 11 - Bizhub C360, C280, C220 User's Guide Network Admin
Konica Minolta 12 - Bizhub C360, C280, C220 User's Guide Trademarks Copyrights
Konica Minolta 13 - Bizhub C360, C280, C220 User's Guide Box Operation
Konica Minolta 14 - Bizhub C360, C280, C220 User's Guide Network Scan, Fax Operation
Konica Minolta 15 - Bizhub C360, C280, C220 User's Guide Printing
Konica Minolta 16 - Bizhub C360, C280, C220 User's Guide Enlarge Display Oper
Konica Minolta 17 - Bizhub C360, C280, C220 Quick Guide Copy, Print, Fac Scan, Box
Konica Minolta 18 - Bizhub C360, C280, C220 User's Guide Fax Driver
Konica Minolta 19 - Bizhub C360, C280, C220 User's Guide Copy Operation
Konica Minolta 20 - Bizhub C360, C280, C220 User's Guide Advanced Features
Konica Minolta 21 - Bizhub C360, C280, C220 User's Guide Security Operations
Konica Minolta 22 - Bizhub C360, C280, C220 User's Guide License Authentication Operation
Konica Minolta 24 - Bizhub C360, C280, C220 Using the Machine
Konica Minolta 25 - Bizhub C360, C280, C220 Pocket Guide
Konica Minolta Bizhub C220 DF-617 Reverse Automatic Document Feeder
Konica Minolta Bizhub C220 Installation Manual
Konica Minolta Bizhub C360, C280, C220 Parts Guide
Konica Minolta Bizhub C360, C280, C220 Poster
Konica Minolta Bizhub C360, C280, C220 Quick Guide
Konica Minolta Bizhub C360, C280, C220 Service Manual - Field
Konica Minolta Bizhub C360, C280, C220 Service Manual - for PKI Card System
Konica Minolta Bizhub C360, C280, C220 Service Manual - Theory of Operation
bsm2
09-21-2020, 04:48 AM
Copyman
tsbservice
09-21-2020, 08:44 AM
If you don't need advanced finishing options, just use DF and paper feed unit, not so much hassle to connect them. Imho first test main unit before even start adding options.
copyman
09-21-2020, 01:37 PM
Copyman
Looks like you have every manual. You can definitely find things like changing tray 3 paper size, how to use control panel, etc. in those manuals.
