View Full Version : Konica Bizhub 808 disable SMB 1.0
pstoric83
09-28-2020, 09:27 PM
I believe we have the newer firmware that can do this but I'm not sure where the setting is. I logged in as admin and went to Network > SMB Settings and I thought it was under "Client Settings" but I'm not sure what to change to get it to scan to our server 2019 using SMB 2.0/3.0? Am I looking in the correct spot? Currently it's set to NTLM V1
https://www.screencast.com/t/TgeuMIaQ
tsbservice
09-28-2020, 09:53 PM
NTLM1 is no go. At What exactly FW version is your machine?
pstoric83
09-29-2020, 12:51 AM
Here is what I see on the ROM version page. I can switch it to NTLM v2 on the page in the screenshot above but not sure if that's the correct setting or not.
ROM Version
MFP Card Version
A7950Y0-F000-GP2-W5
MFP Controller BOOT Program
A7950Y0-1E00-G00-05
MFP Controller Linux Base
Linux-3.10.68
MFP Controller Kernel Program
A7950Y0-1C00-GC1-83
MFP Controller SubSet
A7950Y0-1F00-G00-W4
MFP Controller
A7950Y0-0100-GP2-W5
MFP Controller System
A7950Y0-1000-GP2-W5
MFP Controller Print Controller
A7950Y0-3000-GP0-W1
MFP Controller Print Controller Font
A7950Y0-3F00-G00-U2
MFP Controller Print Controller Demo Page
A7950Y0-3E00-G00-00
Image Reader Controller
A7950Y0-8600-G00-B2
MFP Controller MIO
A7950Y0-5000-G01-C1
Operation Panel Message Data
A7950Y0-8100-GC1-W5
MFP Controller PIC
A7950Y0-8200-G00-F0
MFP Controller PIC Image Parameter
MFP Controller Thread Image Parameter
MFP Controller IR Image Parameter
Finisher
A87G0Y0-0071-G00-14
Machine Controller
A7960Y0-0200-G00-41
Machine Controller BOOT
A7950Y0-0210-G00-01
Machine Controller Printer
A7960Y0-0220-G00-38
Machine Controller Media
A7960Y0-0230-G00-03
Machine Controller IO
A7960Y0-0240-G00-00
Machine Controller Scanner
A7950Y0-0300-G00-09
ADF
A7820Y0-0024-G00-06
Fax Board Controller1
Fax Board Controller2
Fax Board Controller3
Fax Board Controller4
SD
DSC1
DSC2
PK
PI
Panel CPU
A7PU0Y0-8900-G30-03
SCB
A79J0Y0-1A00-G00-03
Power Sub-CPU
A7950Y0-1900-G00-81
SATA Controller
A7AH0Y0-6403-G00-04
Integrated Printer Driver Version
5-4.2-0-GP2-W5
Movie Data
A7950Y0-C000-G00-90
Voice Data
Dictionary Data
A7AH0Y0-B100-G00-01
OCR Library
Authentication Customize Data
Panel Sound Data
A7PU0Y0-C200-G00-00
Loadable Device Driver1
Loadable Device Driver2
srvctec
10-01-2020, 05:18 PM
Yes, that is the correct place to change the setting.
tsbservice
10-01-2020, 06:56 PM
Thanks man I forgot to reply him. My bad seems the weight of age is beating my experience :o
pstoric83
10-01-2020, 06:57 PM
So under client setting change it to NTLM V2?
srvctec
10-05-2020, 03:36 PM
Well, if you want to force it to V2 only, then yes.
blazebusiness
10-05-2020, 04:15 PM
On the Konica's there is also a software switch setting for SMB:
For SMB you can verify what's enabled in Dip sw 219
Hex 00 enables SMB 1 & 2
Hex 04 enables SMB 2 only
