View Full Version : C454 black prints light and also shadowy text
positiveg
10-03-2020, 02:57 AM
Hi guys need some assistance please
We've changed the drum, added new black developer , change the cleaning blade for the IBT
but still no look
please check images. I was browsing the forum and I see something about toner, that's the only thing I haven't changed. But we also cleaned the lens as well.
20200930_170825.jpg - Google Drive (https://drive.google.com/file/d/1AH_W5nZxKe5KJt03I4NwvG4NbkSy5z0h/view?usp=sharing)
Synaux
10-03-2020, 03:21 AM
Please post a test pattern/sheet
positiveg
10-03-2020, 04:49 AM
OK I'll try that.
Also when I ran the test on all the colours only the black showed terribly
Synaux
10-03-2020, 05:02 AM
OK I'll try that.
Find the post by the genius blackcat4866 (https://www.copytechnet.com/forums/members/blackcat4866.html):
C452 Dumpster to the Rescu(r)e!?! (https://www.copytechnet.com/forums/konica-minolta/151408-c452-dumpster-rescu-r-e-4.html)
The internal test might be useful too. Post scans not pictures if possible.
positiveg
10-03-2020, 02:47 PM
Check out how the pics look here
20201003_090126.jpg - Google Drive (https://drive.google.com/file/d/1nDwCBwu6GdDLSORWO50Zh9s2Thg_vJwZ/view?usp=sharing)
copier tech
10-03-2020, 02:50 PM
but still no look
Did you replace the black developer unit or just replace the developer powder?
positiveg
10-03-2020, 05:51 PM
just the powder
copier tech
10-03-2020, 06:04 PM
just the powder
Thats why you have poor K prints.
Fit a new dev unit & a new genuine toner.
Phil B.
10-03-2020, 06:19 PM
+1 on this
tsbservice
10-03-2020, 07:03 PM
+2
positiveg
10-03-2020, 07:11 PM
+2
ok yeah got genuine toner
I'll get a new dev unit
positiveg
10-07-2020, 10:46 PM
Hey guys
well i got the dev unit and installed it, all by myself Yipeee lol
Well the black definitely improved
But there's still some lines
I'm sending you what I got when i ran a test. 46988
blackcat4866
10-07-2020, 11:42 PM
If wanding the laser slit glasses does not help, you'll need a cyan and black drums. The test patterns help diagnosing immensely. =^..^=
positiveg
10-08-2020, 02:06 AM
yeah thanks man
and after seeing the blue lines were wondering
I'll get them thanks much
this is what i got when i ran a job on regular paper
man the colours wicked on this machine
Dropbox - WhatsApp Image 2020-10-07 at 6.08.32 PM.jpeg - Simplify your life (https://www.dropbox.com/s/uhlmcco84s61v6t/WhatsApp%20Image%202020-10-07%20at%206.08.32%20PM.jpeg?dl=0)
positiveg
10-09-2020, 04:08 AM
Do you know what might cause this?
Google Drive: Sign-in (https://drive.google.com/file/d/1AwWruV3WHjV2FQG2XHeUesEN4Kmx-aNe/view?usp=drivesdk)
Two blackline running through the prints. Don't think we ever had this before. Be mindful has a new IBT blade etc
femaster
10-09-2020, 04:12 AM
The link doesn't work. It goes to a page where you have to "request access" to whatever you are trying to share.
positiveg
10-09-2020, 04:15 AM
Sorry hope these upload
It just started happening. Can't recall this ever happening before https://uploads.tapatalk-cdn.com/20201009/d2b7ebfaf1d3bb2192318ac180107c61.jpghttps://uploads.tapatalk-cdn.com/20201009/dc9caf9e2c35ae6619a3b86dca6d3aa3.jpghttps://uploads.tapatalk-cdn.com/20201009/51ffdee49e063b24aeb9d615998e9aac.jpg
Sent from my SM-G955F using Tapatalk
copier tech
10-09-2020, 08:10 AM
I hope that you have learnt that trying to cut corners but replacing just the black developer power & transfer blade only you causing MORE issue.
If you were using genuine only parts you don't run into all these problems.
Did you have these black lines before you replaced the black dev & transfer blade?
The paper you are using looks 'glossy' have you set the correct weight etc?
positiveg
10-09-2020, 11:27 AM
Ok let me explain how it started. We were having these faded black prints and linea and thought that the issue might of come from the cleaning blade not cleaning Bel properly. So we replaced that. Then drum then powder then replaced full developing unit.
Never had those kind of lines before.
It was one of my staff who printed that and yeah I asked her if the gsm was correctly set.
Because again never seen that on that printer. In fact Konika been pretty good. Only issues is couple jams and it's slower than the Xerox C75, and with heavy weighted stock you have to manual duplex.
I'll follow up on the GSM issue and let you know. Only genuine parts we been able to get for this machine so that's all we use.
As I said we don't have a Konika tech on Island so it's only a Canon tech who checks it. Then found great advice on here
blackcat4866
10-09-2020, 11:35 PM
I'm going to guess that at some stage in this saga the black developer was over-toning, dumped toner in the second transfer roller unit. You can clean the second transfer roller with water, just make sure it's completely dry before re-installing.
See the repeating pattern? Is it the same length as the diameter of the second transfer roller?
