View Full Version : firmawre compatibility between minolta and olivetti?
tecnodue
10-05-2020, 01:58 PM
Does anybody knows if i can update a bizhub c220 with the firmware of olivetti d-color c220?
Toxic
10-05-2020, 02:19 PM
No.
Why do you even want to do that?
tsbservice
10-05-2020, 02:53 PM
As side note. On newer Develops I was told KM FW will just fit. But that's other brand and model.
tecnodue
10-06-2020, 08:21 AM
No.
I can't find minolta firmware for c220.
copier addict
10-06-2020, 05:19 PM
I'm not sure if this will help, but I used to get Oce machines and change soft switch 10 to hex 02 and that would make it boot as a KonMin machine. As for firmware, I was able to load KonMin firmware after the soft switch change. I never tried loading firmware before the change so it may have worked before as well.
I am not telling you that it will work for you, but I did have success in the past.
I only use correct firmware but I do know guys that use Develop & olliveti firmware in Konica's they say it works
tsbservice
10-07-2020, 07:22 PM
I believe that's true. However it's not recommended as other functions and features may be affected inadvertently.
Yes you can. I do it practically every day. However only from mf222 c224 and upwards. Worst case the firmware won't be written or simply won't take the USB.
copier tech
10-07-2020, 09:00 PM
Yes you can, I have a few Olivetti models & simply use the Konica Minolta firmware as normal.
rolls.bo
10-08-2020, 08:29 PM
Firmware is the same for all brands but the model must be the same. Never change the soft switch 10, because the certificate settings change
rrrohan
10-09-2020, 02:28 AM
prob easier to just ask for someone to give you the correct firmware :confused:
copier tech
10-09-2020, 07:29 AM
The Olivetti & Konica Minolta firmware are both identical so that would be pointless.
rolls.bo
10-09-2020, 11:52 PM
good you wrote right .......... he is the same firmware
occus
10-12-2020, 11:52 AM
It works not always.
I had a Develop ineo+454e (bizhub c454e) which the new firmware did not accept.... every time it boots to normal copy ready state.
Only afterwards did I see that only the Konicaminiolta models were listed in the aditional .txt in knova.
Firmware updates from konicaminolta are always a bit faster then those from the other brands like Olivetti / Develop.
That means it is not always compatible. But i think the sw switch 10 is the solution.
