View Full Version : Bizhub c3110 " INITIALIZING total memory 1024MB"
Proffice
10-09-2020, 04:48 PM
Hello, I need your help guys.
After powering on a customer's bizhub c3110, display freezes with message " INITIALIZING total memory 1024MB"
Machine irresponsive to any button. I changed the memory board(WW) A6DTR70333 and i tried to update the firmware (as Konica told us), but the problem can't be solved because i can't get to service mode (the machine still does not respond to any button).
Calibration during startup come through, fuser unit is hot and after opening and closing any cover machine rotates.
Any thoughts?
Thank you in advance
tsbservice
10-09-2020, 04:57 PM
Check out this thread, most likely faulty SSDB.
Ineo+ 3110 (Bizhub C3110) (https://www.copytechnet.com/forums/konica-minolta/134775-ineo-3110-bizhub-c3110.html)
tech51
10-09-2020, 07:34 PM
If you tried the ssd board and it’s still the same you will probably have to replace the mfp board.
I had one like this just a couple of weeks ago and the mfp board was the cure.
Also happens on the C3100p FYI.
copier tech
10-09-2020, 10:10 PM
Any thoughts?
There is a special firmware for this exact issue.
Fit the original boards back & update with the restoration tool.
46992
tech51
10-10-2020, 06:57 PM
46992
It’s worth a try but I wouldn’t bet my salary on it!
Let us know if it works...
copier tech
10-10-2020, 08:23 PM
100% worth a try before replacing expensive boards!
waski.th
10-20-2020, 06:22 PM
Hello
I have the same problem. I need NvramClearToolVer101.exe . I can't see it in the infohub. Can you help me?
copier tech
10-20-2020, 09:12 PM
Hello
It is on InfoHub I looked earlier.
Tiagocang
03-12-2022, 09:02 PM
hello im trying to search for that on knova and not find it... only find A6dr30G0304-999 fw is that?
copier tech
03-13-2022, 09:49 PM
Happy to supply this if needed.
Printer & Copier Firmware - www.printerfirmware.co.uk (http://www.PrinterFirmware.co.uk).
Tiagocang
03-13-2022, 10:59 PM
thanks but my question is i can get this from infohub? NvramClearToolVer101.exe? i had some machines with this error and wanna try that before replace ssdb
copier tech
03-14-2022, 09:00 PM
Yes it will be on InfoHub.
Tiagocang
03-15-2022, 11:27 PM
dammit cant find it in the search bar what do u search?
copier tech
03-16-2022, 10:02 PM
52553
Tiagocang
03-17-2022, 08:43 PM
52553
thanks for the help but i tbh dont know what im doing wrong but problably that tool dont exist more on knova i search for Initial Published Date and never appears that tool for Download52564
srvctec
03-17-2022, 09:13 PM
At least here in the USA, look under the "Knowledge" tab of the One Stop area. KBA00026221 has the file attached and all the instructions as well.
tsbservice
03-17-2022, 09:20 PM
Different regions have very different systems. Imho MKM is simply better than European version.
