Hansoon
10-10-2020, 06:07 PM
Well, perhaps its me but I think this is not for the scary ones.... lol
Being sick of high parts costs for our contract machines I decided to try after market belts for the TB-Unit of the old BH-C-220/280/360 series. Got after market belts and cleaning blades. Took me for the first one almost an hour before I found the easiest procedure. The second one half an hour, next one will be less for sure. Most important - but naturally you have this already ;), is preparing an extremely clean workplace without any objects laying around and using surgical gloves. Than I took an old soft woolen blanket, folded many times, to cover the workplace and putting the old TB-Unit on it. After cutting the old belt, removing the cleaning unit and searching for both pressure springs from the corners of the room where they mysteriously went :) I removed the aluminum roller at the cleaning unit side and also the wide metal bracket at the opposite side, Than I cleaned not only the cleaning blade unit but also all rollers in contact with the inside of the belt and everything else around. Important when refitting the new belt is naturally of course avoiding dents and other markings on the belt itself. Since the black plastic bushings in the aluminum roller are constantly falling out when refitting I fixed them in place with a tiny drop of super glue. Installed the new belt and a new cleaning blade, refitted the cleaning unit and priming the belt with lots of yellow toner to avoid a blade flip, finished. All not a joy but can be done......
The rebuild TB-Unit works very well for the moment and we'll see how many prints it can do.
Hans
Hans
