View Full Version : Black streak running through prints
positiveg
10-12-2020, 05:27 PM
So we are getting this long line appear in our prints.
Now we've changed the developer unit. The IBT belt cleaning blade. Cleaned the lens.
Only thing is the black drum but it just started appearing after we put in the black developer unit.
Any suggestions?
Ghttps://uploads.tapatalk-cdn.com/20201012/fcd86d653e210fedf92b5d4dd511308d.jpg
Sent from my SM-G955F using Tapatalk
Phil B.
10-12-2020, 05:37 PM
Any suggestions?
what MODEL? it looks like cleaning blade on the ITB
positiveg
10-12-2020, 05:41 PM
We installed a new one while printer was acting up.
I'll look at it I just took back out the developer unit and out it back in. And I also have another blade and I'll let te technician put that in. Unit is a 454
Thanks https://uploads.tapatalk-cdn.com/20201012/7d224a6d1136c2a395379e2bcef262ee.jpg
Phil B.
10-12-2020, 05:52 PM
aren't you a tech?
looks like the same defect on the paper... did you init the dev unit?
was it a new dev unit or a pull?
looks like a dev unit problem now with the pics.
FrohnB
10-12-2020, 05:57 PM
Thinking it's the charge roller in the drum unit (based on the pattern). May have gotten some developer on it when you replaced the dev. unit.
If you roll up your piece of paper and line up the defects you can narrow it down to certain size rollers.
With the frequent repetition of the marks, i would assume either charge roller in drum unit got contaminated, or maybe a bad spot on the Mag. roller in the dev. unit, or bad seals in that unit.
May be able to clean the charge roller instead of replacing drum unit.
positiveg
aren't you a tech?
looks like a dev unit problem now with the pics.Not a tech that why said will let the Teck check the blade. The dev unit is brand new.
Somwknw told me get genuine parts which have done so. But it's just after the unit was installed getting thar line down the paper https://uploads.tapatalk-cdn.com/20201012/5480ef7658e995893d6fe28dfca00b79.jpg
Phil B.
10-12-2020, 06:18 PM
tsbservice
10-12-2020, 06:25 PM
454(without C) and it prints in color :confused:
I'm speechless :D
Just in case it is color unit
- remove K and one of CMY drums
- swap the chips between both drums
- do some tests
positiveg
10-12-2020, 07:51 PM
I'm speechless :D
- do some tests
Sorry it's the C454 lol come on I'm not that crazy :rolleyes:
Phil B.
10-12-2020, 07:59 PM
well it WOULD help if you described the problem and machine fully :mad:
positiveg
10-12-2020, 08:49 PM
Found out it's the drum. We also changed the blade on the IBT. The tech is here and was able to run a few prints stop it halfway then we saw the same pattern that you see the prints.
positiveg
10-12-2020, 09:59 PM
well it WOULD help if you described the problem and machine fully :mad:Thanks. True.
Well it's a C454
And as I showed in the photo there are black streaks. What the tech found after stopping prints halfway and pulling the drum was that the same markings in the drum.
So I've ordered two drums but waiting for them to get to the island tomorrow, hopefully.
In the meanwhile we are trying to see what we can get from this black drum as we have some jobs to run. And the Xerox C75 waiting on parts as well. Delivery heavily hampered by Covid man
positiveg
10-13-2020, 12:42 AM
Great stuff the tech cleaned out the roller etc we stop getting the mark. But for sure the black drum needs changing as we aren't getting strong black when we print
But for now it should suffice hopefully till the drums get here either tomorrow or Wednesday, thanks much appreciate the help.
allan
10-14-2020, 01:57 AM
Hehe:D.
Funny stuff.
You could have checked the charge assy on the drum unit.
Going after market can cause some headaches of its own.
Glad its working.
Thanks to the dentist aka Phil we got some info.
Model numbers and other relevant info like total counters and parts life please.
Phil B.
10-14-2020, 02:53 AM
Hehe:D.
Funny stuff.
Glad its working.
thanks brother..
I don't mind playing ' The Dentist ' with end users.. what flames my cookies is having to do it with techs.. guess that's just my service manager side coming out.:cool:
Couldn't do it without the rest of you guys tho.
positiveg
10-14-2020, 08:56 PM
Ok I've gotten the new black drum and Cyan drum both genuine.but no change. In fact, I'm attaching some pics. One is colour the other same image black and white then a business card that background should be black https://uploads.tapatalk-cdn.com/20201014/f535ea597bc4490bbefef27bf3196bfc.jpghttps://uploads.tapatalk-cdn.com/20201014/f671cf368da70040ebff1d7cf7c710c4.jpghttps://uploads.tapatalk-cdn.com/20201014/08c7a19c740a4564b93cf746fa72c570.jpghttps://uploads.tapatalk-cdn.com/20201014/2b9716d2187886aaf2b7fb3fe5d933c1.jpg
tulintron
10-14-2020, 10:01 PM
My humble opinion says that this is a problem in the development unit. Are you using genuine toner?
Is there any input in addition to working time?
The black development unit may have little revealing, causing these failures
positiveg
10-14-2020, 10:12 PM
I just changed the unit. Bought a new unit installed two days ago. Guessing it should have genuine powder in there as well.
Could it be the IBT?
tsbservice
10-14-2020, 10:19 PM
Looking at samples definitely K developer unit is depleted. Those machines can quickly empty developer into WTB if/when they decide to.
