View Full Version : i series reset tools
jwai
10-16-2020, 03:18 AM
Hi everybody
I wanna ask KM provide reset tools for i series?
Best regards,
tsbservice
10-16-2020, 06:03 AM
Are you solving specific problem or just in case?
jwai
10-16-2020, 02:53 PM
HI tsbservice,
One C250i has issue that boot up only 25%, later on I will take CPUB and SSDB for testing.
I consider when CPUB is not relative with this case, I can initialize it with this tools like the procedure on previous 4e series.
Bix
10-16-2020, 02:56 PM
Change the STRB and update the firmware to G00- B6
jwai
10-20-2020, 05:13 PM
Thank you Bix.
Since I tried the following :
- Enter the tech Rep mode by reset key + main SW on
- Enter the load FW mode by stop key + main SW ON
They all display 25% boot up screen with black dot only, so I'm not sure the condition of CPUB is ok or not.
copier tech
10-20-2020, 09:16 PM
Thank you Bix.
With the iseries you use the small button behind the control panel to load firmware.
Woxner
10-20-2020, 10:09 PM
one way to test storage board is to remove it and see if it will load firmware. it wont load controller though
Woxner
10-20-2020, 10:10 PM
and the 8 series reset tool is used for i series as well
jwai
10-21-2020, 01:06 PM
Yup, I really use this way attempt to load the B6 firmware.
However, it stay on 25% boot up screen with up left corner dot only.
jwai
10-21-2020, 01:37 PM
I don't have this tool :(
jwai
10-22-2020, 11:11 AM
Thank you your advise, I tried this day however it stay same. ( 25% boot up screen with black dot )
