View Full Version : Konica Minolta C454e- Disable User Settings Password
Lydah
10-19-2020, 12:33 AM
Hi all,
I have a C454e here which has a user settings password.
I would only like it to be set on administrator setting alone. I believe there's a SW switch for disabling the user settings password.
Will really appreciate your kind response.
Thanks.
Terna247
10-19-2020, 01:50 AM
You could either delete the user boxes registered with those user passwords..... Unless you are talking about the CE password
Sent from my Infinix X606C using Tapatalk
rrrohan
10-19-2020, 01:55 AM
Hi all,
Thanks.
200 set to HEX 20
Lydah
10-19-2020, 04:21 AM
Its not the user box password. Its the User Setting in the Administrator Settings>Utility which they have enabled the password.
Thanks for your response
Lydah
10-19-2020, 04:36 AM
200 set to HEX 20
Have tried and it enable the utility password but I disabled it again.
Sendragon
10-19-2020, 12:28 PM
Switch: 71 Hex: 0 ?
allan
10-20-2020, 01:23 AM
Backup and wipe the machine loose the machine settings.
The right answer is out there. I am just to lazy to read.
ezzysi
10-04-2023, 12:05 PM
Switch: 71 Hex: 0 ?
Its an old thread now but this has just helped me out !!
Worked on a C258, before changing 71 to 0 the user settings were locked and couldnt do a meter count print off without inputting the admin password.
