View Full Version : Miscellaneous Does the 8 series transfer unit fit the 4 series
copier tech
10-28-2020, 10:03 PM
Quick question, does the C458 transfer unit fit the C554e?
Different part number but from memory they look the same (I don't have 2 to compare)
drowranger
10-28-2020, 10:07 PM
HI yes it will fit to 4 and 6 series up to 55ppm.
copier tech
10-28-2020, 10:16 PM
Thanks, I have a ripped belt in a C554e but only have a new C458 belt unit.
EarthKmTech
10-30-2020, 11:05 AM
they are interchangable.
If you swap over the top metal plate (use the new sep claw with the new belt) you can even fit the correct black plastic guide and its the perfect crime as it looks completely correct too.
MVPunisher
10-30-2020, 04:35 PM
Good to know.
