C3850 not loading security certificate
  • pickle8486
    • Aug 2013
    • 26
    Hi Guys,
    So I got to change the security certificate on this c3850, I have updated the software, done the dipswitch, and I am still having issues with the machine taking the certificate in pagescope. I have called solutions, they walked me through, even to the point of giving me a repair request code. I am thinking of doing an initialization on the machine and reformatting the hard drive. Anyone got anything to save me from having to do this?
  • emujo2
    • Mar 2017
    • 1580
    Re: C3850 not loading security certificate
    If there are any apps trying to use the Open API you will have issues with making SSL changes. Since you mentioned the dip switch I assume you need the SHA256 cert..Here's how I normally make a change like this
    1. Remove any apps that utilze the Open API (3rd party stuff or marketplace)
    2. Creast a new SSL certificate and set it as the new default
    3. Delete any un needed SSL certs.
    I do not know if the original cert is SHA1 and you try to upgrade to SHA256 if this will cause a conflict..There have been a few machines that did need a HDD format/data init to remove the greyed out settings. E
    • Bix
      • Apr 2018
      • 1421
      I believe that in this model the new encryption levels are not supported
      • emujo2
        • Mar 2017
        • 1580
        SHA256_RSA2048 is supported with firmware and a dip switch change. I can assure you that after getting these machines to fianlly accept Equitrac, OM, and Papercut, you can't do it with the less secure SHA-1 (w/o making some really dangerous security setting changes to the server. E
