View Full Version : Miscellaneous Black square when scanning only
zackrch
11-04-2020, 09:55 AM
Hello, Has anyone ever had a problem when scanning there will be a black box in the middle of the paper?Using konica model B/W 458E.This is happen only if use for scan other than that nothing wrong.I have reconnect the ccd cable,prcb cable and all other cable that connect to the scanner unit and also i already upgrade latest firmware.
47203
slimslob
11-05-2020, 02:50 AM
Might be a memory or HDD error in the portion use for the scanning function.
Might be a memory or HDD error in the portion use for the scanning function.I had the very same issue on a Ricoh machine once; a memory module was bad.
Before you start blindly replacing stuff, see if the problem changes when scanning at different resolutions.
If it does, it’s almost definitely a memory problem.
zackrch
11-05-2020, 03:57 AM
Thank you all, right now i do physical format for hdd, i will update later.
