View Full Version : KM 458e- Black box when scanning only
zackrch
11-05-2020, 02:17 AM
Hello, Has anyone ever had a problem when scanning there will be a black box in the middle of the paper?Using konica model B/W 458E.This is happen only if use for scan other than that nothing wrong.I have reconnect the ccd cable,prcb cable and all other cable that connect to the scanner unit and also i already upgrade latest firmware.
47213
Zesti
11-05-2020, 05:52 AM
What about copying????
Scanning from ADF or Glass????
zackrch
11-16-2020, 02:18 AM
Scan using adf or glass same problem but copying is okay, my conclusion is the mfpb problem.
Why MFPB? I'd look for something wrong with the scanner first.
tsbservice
11-16-2020, 09:15 AM
Disconnect DF and remove dual scan board. Does it scan correct that way?
acusso1234
11-16-2020, 10:45 AM
https://www.copytechnet.com/forums/konica-minolta/131702-c454e-df701-2nd-side-scanning-issue-post739264.html?highlight=#post739264
allan
11-16-2020, 10:49 AM
So LEF on the glass and DF?
Alway in the same position?
Main scan line failure?
zackrch
11-16-2020, 11:15 AM
I guess mfpb problem because when I scan to the userbox and I zoom in on the machine there will be a picture like a damaged TV when i the zoom out it will disappear, if i print from the userbox all is fine.I changed ram/eMMcb and hdd already but no luck.
47325
Zesti
11-17-2020, 10:38 AM
47325
Couldn't got it:confused:..... scan in user box showing pixels on preview but when print from box print is fine??????
zackrch
11-17-2020, 10:46 AM
Yes correct but my senior said change scanner board first if still same then proceed mfpb
tsbservice
11-17-2020, 11:46 AM
What's wrong about trying it without dual scan board?
zackrch
11-17-2020, 12:05 PM
What do you mean? If i take out the board how can i scan?
Zesti
11-17-2020, 12:19 PM
Scanner board is for dual scanner DADF only. But the problem is also showing from glass. Am I right???
mearmi
11-17-2020, 12:20 PM
tsbservice means
Disconnect the Document Feeder and Remove Dual Scan Board from the machine and scan from Platen Glass.
tsbservice
You claimed problem from both glass and DF right? Without DF you still should be able to scan from glass.
zackrch
11-17-2020, 12:49 PM
This is nothing to do with df. Scanner and df not sharing board thy are separate.btw thanks for your opinion.
splblazer91
11-17-2020, 04:37 PM
Just do what he said and disconnect the adf and ds board. DS can board can cause all kinds of issues unrelated to the ADF.
copytechman
11-18-2020, 06:59 PM
Agree with this statement... had a ds board go bad and cause erratic print issues with a c454e..
Regards.
A.
Toxic
11-18-2020, 07:45 PM
Sometimes you should follow advice even it is not clearly logic, especially with some strange problem like this one.
