View Full Version : TCR Sensor C7000 vs C6500
wjurls
11-06-2020, 10:01 PM
Does anyone know if a TCR Sensor for a C7000 will work in a C6500 as well? They are different part numbers, but I'm hoping it's the same basic sensor.
Thanks, Lee
Phil B.
11-06-2020, 10:05 PM
Thanks, Lee
i doubt it
wjurls
11-06-2020, 10:26 PM
i doubt it
Me too. Just hoping so. I have a customer who needs one for a C6500 and I will already be in their area tomorrow and I have a new C7000 dev unit, but not a C6500 TCR. :mad:
rrrohan
11-07-2020, 09:12 AM
I don't do production but if I had the parts guide I'd just see if PN are the same
Sent from my Pixel 4 XL using Tapatalk
Toxic
11-07-2020, 06:55 PM
You should try it, they can be the same thing.
Recently have problem on C6000 and replaced transfer roller HV wire from C5501, i think whole transfer belt is totally the same and some more parts for sure.
BTW i use DU104 (C6000,7000) for years on C5501.
Phil B.
11-07-2020, 07:02 PM
IF the toner formulation is not the same the TCR sensor has to be different
Toxic
11-07-2020, 07:21 PM
Agreed,I just google both sensors,they look same except different connector.
Just searched,it seems toner is the same compound.
tsbservice
11-07-2020, 07:44 PM
Aftermarket toner sensors seem to fit both press.
Konica Minolta Toner Sensor A1DUM50800 bizhub PRESS C6000 C7000 (https://arcservicesco.com/konica-minolta-toner-sensor-for-bizhub-press-c6000-c7000)
Phil B.
11-07-2020, 07:48 PM
well we all know how much KM's like aftermarket toners...
even with the connector being different I wouldn't trust trying to fit one in.
Toxic
11-07-2020, 07:59 PM
This look like OEM tcr sensor but for C6000,7000 , i dont see anywhere they clame to fit on C6500...
tsbservice
11-07-2020, 08:03 PM
Phil you are right on aftermarket toners. My guess is both machines use same toner formulas I just hopefully seek for evidence he can use what have in hand.
Phil B.
11-07-2020, 08:04 PM
didn't think it would.
tsbservice
11-07-2020, 08:12 PM
Oops, seems I missed the main plot...sorry guys :o
Toxic
11-07-2020, 08:45 PM
Toners are the same compound so sensors are propably the same except connector.
If i would in some emergency situations i would just replace connector and fit.
On the field i have to improvise so many times sensors,termistors,heater lamps,clutches... with just different connectors or similar small difference to back machine to working condition without waiting for original part.
https://i.postimg.cc/Hc2SD4FQ/612-vs-616.jpg (https://postimg.cc/Hc2SD4FQ)
tsbservice
11-07-2020, 08:52 PM
Exactly my thoughts. Still You and Phil are correct on topic.
tulintron
11-09-2020, 01:37 PM
I have already replaced it a few times and I can say that it works. Just cut the wires and solder to the correct connector. The connections are different, but the sensor is the same. I can assure.
wjurls
11-09-2020, 06:15 PM
Thanks everyone for the input. I managed to get the correct TCR sensor in time for the service call. C6500 and C6000 use the same developer so I assume that the toner would be the same. In this case, the problem turned out to be defective developer (assuming customer did exactly as claimed prior to error). New sensor still threw immediate code C-2453. Dumped old DV and replaced with new and all was well. I will have to remember the connector modification for future problems.
Lee
tsbservice
11-09-2020, 06:28 PM
Lee
Thanks for follow up Lee 👍
