View Full Version : Error Code C2404
Engradenuga
11-13-2020, 07:30 AM
I have a machine I am currently working on. Its Konica Minolta 1070 with error code c 2404. How do I go about it.
allan
11-13-2020, 11:28 AM
Obtain a service manual.
Then describe the problem in full and what you have tried to do to repair the problem.
If you are not a tech then getting someone out will be a good idea.
See these machine go from bad to worse if an inexperienced hand gets to it.
Engradenuga
11-13-2020, 07:48 PM
Already checked the service manual. The code was referring to the erase lamp. I am sure the erase lap isn't faulty and the fuse on the PRCB is still intact. The code comes and goes at intervals
Phil B.
11-13-2020, 07:52 PM
how are you sure? Have you left the door pegged and watched it come on and go off?
a tech of 2-10yrs should explain the problem in more detail if he requires help.
