View Full Version : Error Code E206 on setting up a new C3350
soaponarope
11-18-2020, 12:44 PM
No error code listed in manual. Do you know what it means?47347
Synthohol
11-18-2020, 02:15 PM
i assume by the pic its a C3350i
probably trying to reach marketplace.
see if it can be disabled.
i didnt see anything in the manual either so thats my best guess.
soaponarope
11-18-2020, 02:28 PM
Yes i machine.
soaponarope
11-18-2020, 02:50 PM
Situation is slightly different now. Error has gone, machine works ok. However after about a minute the display goes off and the whirly-gig symbol appears. If you touch the screen it comes back and works fine. A bit like an energy save situation but it isn't and energy save settings have no effect. It looks as though it is trying to load something...
Synthohol
11-18-2020, 05:07 PM
It could be running the marketplace screensaver
soaponarope
11-18-2020, 05:25 PM
OK. How do I get rid of that?
copier addict
11-18-2020, 08:41 PM
To disable the MarketPlace screen saver perform the following:
1. Enter the Utility> Administrator mode
a. default password is 1234567812345678
2. Select System Settings
3. Select Reset Settings
4. Select System Auto Reset
5. Turn the Screen Saver Function toggle to O
copier tech
11-18-2020, 08:45 PM
I had a similar issue.
Look at the error history in CE mode, mine logged C2204 yet error on the on screen was E201.
Synthohol
11-18-2020, 10:26 PM
thats damn good advice right there!
soaponarope
11-18-2020, 10:38 PM
You 3 have been really helpful and I will try your suggestions tomorrow and let you know how I get on. This is the first time I have raised a thread on here and am impressed. Minolta themselves do not know what that code means...
soaponarope
11-19-2020, 10:12 AM
This resolved it so thank-you very much copier addict!
copier tech
11-19-2020, 06:49 PM
Thanks for the for the feedback i've also not heard back from my client after turning off the screen saver & marketplace up.
However not sure why this would throw an E code error not in the manual.
