View Full Version : Miscellaneous Konica Minolta C284e Scanning issue (Sent as mime-attachement)
mearmi
11-23-2020, 10:43 AM
Hi All
Client is scanning (email) documents as pdf but getting as mime-attachments. And cannot open as pdf.
Another issue is when she scans 10 pages. it comes separately as 10 emails :
Message from C284e [1/2] to [10/10] 10 separate emails.
Please advise.
Thanks and Regards,
mearmi
Bix
11-23-2020, 11:06 AM
Hi, most likely they have activated this.
You have to remove.
47383
CP-1015
11-23-2020, 12:53 PM
Hi,
what file extension get your client? You can chose file type in Scan menu.
mearmi
11-23-2020, 06:24 PM
Hi,
whatever File type you select PDF JPEG TIFF. They get as mime
tsbservice
11-23-2020, 06:35 PM
Try to turn off S/MIME under [Network] - [E-mail Setting] - [S/MIME]
mearmi
11-23-2020, 11:37 PM
it is already off
rrrohan
11-24-2020, 02:28 AM
If mime isnt enabled at copier then logically it has to be a I.T issue
mearmi
11-24-2020, 10:27 AM
FTP scan is fine.
only getting the issue in scan to email
xagerated
11-24-2020, 05:29 PM
There are a few things that I would try. First off try it with different smtp settings instead (gmail, outlook, etc), see if you are still getting the same problem. If you are, then you know that there is probably a setting that you are missing in the machine itself. If not, then the problem lies on the email server side. Also, check if the machine is trying to encrypt or to add a digital signature to the scan to email and turn that off if it is.
