View Full Version : FS-9530DN - Call Service F030:0300100?
What does this error code mean on a Kyocera FS-9530DN?:
Call Service
F030:0300100
It's been showing up intermittently on the printer. Powering off seems to clear it for a awhile.
Thanks!
blsquires
11-13-2008, 01:54 AM
Call Service
F030:0300100
Thanks!
Main PWB system error Defective main
PWB.
Replace the main PWB and check for correct
operation.
although this is the fix by the manual they usually only need a firmware update
10871087
11-13-2008, 06:32 AM
Agreed, you might want to add in a re-seat of connectors and boards for good measure.
Thank you -- that's very helpfull!
LNorris
11-14-2008, 03:08 AM
double-check the print driver make sure its the right version with the pc/server being used. we had this show up on a color Kyocera printer. swapped boards, firmware and such, still didnt work right. put it in my office and it works fine. this was a c5015...we put a 5020 in its place and it works fine now.
madas
12-01-2008, 11:14 PM
this code is also associated with corrupt files sent to the printer. i have never had to change the board or dimm. turn off the m/c unplug from the network turn on the m/c it should reset. check print queue and delete the offending file recconnect to the network should be fine
KyoSpec
12-16-2008, 11:12 AM
Call Service
F030:0300100
Thanks!
It is extreemly unlikely the error is caused by a hardware fault, simply updating the driver often resolves the problem, worst case updating the firmware should resolve the fault
