r4roty
12-12-2020, 01:39 PM
Hello All
While trying to bring out the transfer belt of this copier, I removed the fuser unit however after re installing the removed items and switched on power the copier failed to warm up but threw up a 3925 code. Upon trouble shooting I discovered that one wire in harness by the right side door to the center temp sensor pulled out, after correction copier failed to reset.
Now the main issue is this: I entered service mode scrolled through the menu couldn't find fuser reset. Maybe there are steps I'm not taking .
Your help to resolve this will be much appreciated. Thanks
