View Full Version : Miscellaneous Blue toner on edge of large paper prints
positiveg
12-16-2020, 03:56 PM
Hi there guys this is the C454e
printing now
i am not sure why it's happening
So some help would be appreciated. https://drive.google.com/file/d/1r03nh0HKxaJ-VUMTSSAmFDgarZPfsIBf/view?usp=sharing
Google Drive: Sign-in (https://drive.google.com/file/d/1r03nh0HKxaJ-VUMTSSAmFDgarZPfsIBf/view?usp=sharing)
positiveg
12-16-2020, 04:01 PM
Was trying to upload image or link via computer no luck. So using the the app
https://uploads.tapatalk-cdn.com/20201216/aa4156a9c0c62116b8e9c9687eec2c3b.jpg
Sent from my SM-G955F using Tapatalk
BillyCarpenter
12-16-2020, 04:04 PM
What have you done to resolve the problem?
Total counter?
PM counter?
dibyendu2008
12-16-2020, 04:16 PM
in color or garyscale mode mode this blue lines are coming? please check any voltage aching or leackage in Imaging unit. what is the life of all imaging units?
BillyCarpenter
12-16-2020, 04:25 PM
My best guess would be drum/drum blade. It would help to know how many pages have been printed on the PM parts.
Synthohol
12-16-2020, 04:29 PM
If I am to assume that was printed short edge first, I'd print portrait to get a clear view of what's happening.
BillyCarpenter
12-16-2020, 04:31 PM
I got $1 that says it was printed short end first. Bet? :p
printing now
Google Drive: Sign-in (https://drive.google.com/file/d/1r03nh0HKxaJ-VUMTSSAmFDgarZPfsIBf/view?usp=sharing)Normally I would say drum. Did you swap out the drum with another color drum?.. Did the issue follow the drum?... If not, definitely pull the DV unit and check it out. Something is causing that Cyan to pull like that
Sent from my SM-G955U using Tapatalk
CP-1015
12-16-2020, 04:43 PM
First I would clean PH glasses. Than I would have a look to the drum.
tsbservice
12-16-2020, 04:58 PM
Do exactly what Reed said. What is the distance, if print is SEF and has gritty feelings then definitely take a good look at developer unit.
Albonline
12-16-2020, 05:28 PM
Do exactly what Reed said. What is the distance, if print is SEF and has gritty feelings then definitely take a good look at developer unit.,
The root cause of this is usually. the black unit misting ,fouling cyan charge system.
Synthohol
12-16-2020, 07:24 PM
It's a repeating pattern on the drum. It's the drum.
Firmaware
You must change drum and developer and set TCR value for cyan -2
Gesendet von meinem SM-G980F mit Tapatalk
Toxic
12-16-2020, 07:49 PM
Obviosly its damaged drum, same mark is repating.
Measure distance betwean 2 same marks and if it is arround 95mm it is drum for sure.
tsbservice
12-16-2020, 07:51 PM
94mm to be precise ;)
BillyCarpenter
Good catch, guys. I failed to notice the repeating pattern.
