View Full Version : Miscellaneous Ineo 458e freezes when turned on
pinspin
12-27-2020, 03:27 PM
The copier, when turned on, goes through most of the loading stages and at the end freezes for 5-10 minutes. Then it spontaneously continues downloading and works as usual. We performed a firmware update , changed the Main Board, EMMC, HDD, the fuser - it didn't help. We will be grateful for any help. Thanks
tsbservice
12-27-2020, 04:04 PM
Are some options installed? Or external memory? Remove any if installed PLUS dual scan DF board and try without it.
Max
12-27-2020, 05:24 PM
Sounds like its waiting for something to come to a ready state. Then times out and carries on. Any 3rd party hardware/software, licence for something? Refit every connector at the back and disconnect every option.
tsbservice
12-27-2020, 05:38 PM
Good idea. Bizhub Marketplace may acting up.
pinspin
01-10-2021, 01:37 PM
It was Dual Scan Image Processing board (DSIPB) .
Thank you very much for the help
copier tech
01-10-2021, 10:35 PM
Thank you for the update.
