View Full Version : C7000 Bizhub
afterhours
12-30-2020, 01:08 PM
Good morning everyone. I have a customer with a c7000. It keeps getting the jam 9202 when doing 2 sided. I've replaced both duplex motors, all the sensors in the duplexer and the selinoid. Still keeps jammimg with the same code. I'm out of ideas. Any help.would be greatly appreciated.
Sent from my SM-G981U using Tapatalk
qbert69
12-30-2020, 01:19 PM
Sent from my SM-G981U using TapatalkAny rubber feed rollers that are dusted with paper dust or glossed over that need to be cleaned with rubber cleaner???[emoji848] sometimes slippage can occur from dirty/fouled feed rollers!!! Can happen even if sensors are cleaned and motors are working!!! I've seen it happen on certain brands of machine (ahem...r!coh!) where the bridge unit between the fuser and finisher got dirty rollers and would have a slippage, delay and subsequent error code going into the finisher!!! Once the bridge unit feed rollers were cleaned, nary another jam/error code!!![emoji57]
Sent from my SM-N950U1 using Tapatalk
afterhours
12-30-2020, 01:21 PM
Sent from my SM-N950U1 using TapatalkThank you. I have done that.
lartis.aineias
12-30-2020, 01:39 PM
Try to change this actuator https://uploads.tapatalk-cdn.com/20201230/08d9f1312ff4f5c2f7efcd17af2c8071.jpg
Στάλθηκε από το SM-G975F μου χρησιμοποιώντας Tapatalk
afterhours
12-30-2020, 01:43 PM
Στάλθηκε από το SM-G975F μου χρησιμοποιώντας TapatalkThank you. I will do that later today and get back to you.
afterhours
12-30-2020, 07:43 PM
Στάλθηκε από το SM-G975F μου χρησιμοποιώντας TapatalkYou are the man!
@lartis.aineias
That did the trick. So weird,.it was only slightly warn at the tip of the actuator but enough to cause the problem.
lartis.aineias
12-30-2020, 08:45 PM
You are the man!
@lartis.aineias
Sent from my SM-G981U using Tapatalk3 days I was trying to solve this problem. and when i found it i had the same reaction with you! crazy
happy New Year!
