View Full Version : CYAN Konica C360 color problem
Mahery
12-30-2020, 02:30 PM
Hello,
After adding some cyan toner in the developer unit, I have this problem. what are the solutions to remedy this problem. Thank you in advance.
47738
Synthohol
12-30-2020, 02:50 PM
check level history 1, the atdc level must be waaay off.
was it real c360 toner?
id run cyan halftone test pages on 11x17 until the level gets back where it belongs. (if possible)
Mahery
12-30-2020, 03:21 PM
Synthohol,
Yes it is real c360 toner and I have already done a full page cyan test over 30 pages. has been another solution to offer me please.
tsbservice
12-30-2020, 04:05 PM
What are exact cyan tcr readings atm? Clearly you overtoned developer unit and we don't know how much. Any error code? Remove cyan toner and then do some more halftone patterns at max density.
Synthohol
12-30-2020, 07:39 PM
also reseat the drum, maybe a dirty ground connection?
femaster
12-31-2020, 06:11 AM
I guess I'll go out on a limb here ask the obvious question: Why did you add toner to the dev unit to begin with? By the comment that you added toner, I hope you don't mean that you just poured some in there. :confused:
Mahery
12-31-2020, 07:37 AM
tsbservice,
I do not understand your explanation.
Synthol,
I have already changed with another drum unit for c280 and also changed the developer unit for c280 too but the problem persists.
Femaster,
Before I had concerns where the cyan density level is the cause of the addition of cyan toner in the cyan developer unit.
blackcat4866
12-31-2020, 02:48 PM
I think you all have this topic thoroughly covered.
Clearly toner density is running about 50%, and the excess will continue to feed off onto copies until it settles down to ~4%. From what I've read of your posts Mahery, you will not be able to fix this machine yourself. You don't even understand the basic industry terminology.
Please take my advice: Have a professional look at it before you find a way to do some more expensive damage. =^..^=
