View Full Version : Error Code Sc 285
kanagavel
01-07-2021, 09:41 AM
Hi friends, my machine is ricoh MP C5502 i test the colour pattern the alignments are not ok then i try to do ITB forced line position adjustment on SP2111 that C, B, A option first i do C option result showing failed i try again anf again then its comes SC 285 error code. Then i go by the manual instruction i chenge from other machine ( ITB unit, all the 4 drum units, laser unit, ID sensor) but still the problem not solved.
So i need help i want to know how to solve this problem friends please teach me how to solve this problem friends.
Phil B.
01-07-2021, 11:23 AM
1) you need to post in the proper forum: https://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/
2) did you run ACC auto color correction?
3) changing parts from one machine to another you still have to run the appropriate SM adjustments
4) you have the manual ... RTFM
kanagavel
01-08-2021, 03:36 AM
Hi sir thank you for your reply.
1) i didn't do the ACC
2) i don't know what is SM adjustment, can you please teach me.
3)sorry sir i don't have RTFM, i just refer to the printcopy.info website
So sir can you please help me to solve this problem
Phil B.
01-08-2021, 03:38 AM
R = Read
T= the
F = frigging
M = manual
if you don't have a real service manual, make a small contribution to CTN, that'll get you a Contributor Badge on your profile then the guys with the manual will probably get you a copy ...
https://www.copytechnet.com/forums/service-manual-requests/
kanagavel
01-08-2021, 03:54 AM
R = Read
T= the
F = frigging
M = manual
Ok sir thank you for your reply sir.
slimslob
01-08-2021, 04:57 AM
You wasted a lot of time running forced line position and changing various parts but I don't see anything about you cleaning the ID sensor assembly first. Now go and clean the Image Density sensor assembly and any toner hazing around it. If that does not correct the problem, replace the ID sensor assembly with a new one. A new one from Ricoh will come with a sticker that was settings that are specific to that board. If those values are not correct you will continue to have problems.
VirginiaKMcGowan
03-23-2021, 10:06 PM
Hello, I am a college student and I was reading How to Better Manage Your Time As a Student (https://www.swaay.com/how-to-manage-your-time-better-as-a-student) on a website and while reading, by mistake, I clicked on your post. And I am glad I have found your post because my friend also facing the same problem and he still he can't find its solution and I would love to share with him. I hope it will help him out.
slimslob
03-23-2021, 11:09 PM
The problem is most likely a dirty or defective Image Density, ID, sensor assembly. Depending on the machine there are a few other things that can cause it. I would suggest that he obtain a service manual for the specific model he owns as getting at the sensor assembly can vary. You or he can put a request in the Service Manual Requests forum. https://www.copytechnet.com/forums/service-manual-requests/
KarenCBorders
07-02-2021, 12:05 PM
Hi, I also face this same problem, And I am also finding the solution of this problem. If will get the solution of it I will let you know. By the if you are thinking about start a new business in lemonade then I suggest you to make lemonade stand business plan (https://www.ogscapital.com/article/lemonade-stand-business-plan-sample/) with the help of ogscapital. I also take their help. That's why I suggesting you this.
