View Full Version : 4 series, Engine DipSW to reset toner to full
rrrohan
01-14-2021, 06:46 AM
4 series, Engine DipSW to reset toner to full, is this possible. I cant recall if this is only on 8 series and newer. If it is possible could someone please remind me of the
tsbservice
01-14-2021, 07:26 AM
Not possible on 4/4e series as far as I know. What problem you have?
It often happens to me that the toner is almost finished when it is actually full or vice versa. I wait for the printer to stop due to low toner, remove and reinsert the toner tube to return to 100.
rrrohan
01-14-2021, 07:59 AM
Customer used non genuine toner and it was changed early. Was gonna see if I could just force it to report full but I'll just tell him to ignore it.
Sent from my Pixel 4 XL using Tapatalk
gere1
01-14-2021, 03:43 PM
for series 4 dipsw1 resets all toner
tsbservice
01-14-2021, 04:37 PM
You mean all 4 toners?
gere1
01-14-2021, 04:59 PM
yes the 4 tonerIt usually does well but I have had some equipment that does not reset it
allan
01-14-2021, 05:17 PM
Question is what else does that reset?
gere1
01-14-2021, 05:42 PM
just the tonerWhat else do you want to restore?I use google translator to see if I do not understand the question well
wjurls
01-14-2021, 11:05 PM
I wonder if that switch will work on my truck too? Change a dip switch and boom! Full tank!!
tsbservice
01-15-2021, 06:30 AM
It should...plus antifreeze, engine oil and brake fluid to make them 4 :cool:
Copier repairman
01-29-2021, 03:55 PM
I have DIPSW enabled on the 4 series.
I ran DIPSW1, but the toner was not full.
copier tech
01-29-2021, 07:29 PM
This option is not available on the 4 series.
Simply remove all the toners, run a print run, when the copier calls for a toner refit the used ones this will reset the toner life count.
Synthohol
01-29-2021, 10:08 PM
...Simply remove all the toners, run a print run, when the copier calls for a toner refit the used ones this will reset the toner life count.
thats been my "cheat" for years!!
copier tech
01-30-2021, 12:03 PM
Yup, happens when the clients replace the toner before the copier calls for it.
rrrohan
01-31-2021, 05:07 PM
Yeah I removed toner and did some 255 prints. All good now.
