View Full Version : C35 scanner
wynter17
01-14-2021, 12:07 PM
Hello,can the scanner be disabled? Thanks
Sent from my SM-G980F using Tapatalk
allan
01-14-2021, 01:37 PM
No just fix the belt or ribbon cable.
You should be able to remove the scan icon from the panel
tsbservice
01-14-2021, 04:55 PM
Nope.
Machine won't function as he has scanner error code. He just want to isolate scanner and use it only as a printer.
wynter17
01-14-2021, 05:23 PM
Nope.
Machine won't function as he has scanner error code. He just want to isolate scanner and use it only as a printer.Yes,exactly
Yes,exactly
What about disabling it in the driver? Or just disconnecting it physically?
Synthohol
01-14-2021, 05:43 PM
Or just fix it?
That's like asking to have a refrigerator freezer combo but just turn off the freezer part.
It does not work like that.
Or just fix it?
I don't totally disagree but at the same time repairs can cost, if the client doesn't use it I can see why the 'just turn it off' plan would be appealing.
tsbservice
01-14-2021, 05:48 PM
The reason for this is called machine initialization process. Every machine I know has it. If you simply disconnect scanner from main board it won't initialize. I may check service manual but strongly believe that allan knows the answer.
Just to double check myself I went and disconnected the ADF on my Taskalfa 3551ci and it turned on just fine... Then I realized noone ever said ADF and my assumptions are shameful :(
wynter17
01-14-2021, 06:00 PM
Or just fix it?
It does not work like that.The thing is that we already replaced the scanner lamp 2 times in 6 months,now will be the third time,the printer itself is in good condition thats why i wanted a way to disable it.
tsbservice
01-14-2021, 06:02 PM
M94 not at all as far as I'm concerned :)
tsbservice
01-14-2021, 06:19 PM
Did you tried what allan suggested?
allan
01-15-2021, 05:40 AM
Look at the bottom of the ribbon cable for wear.
Been scraping of the isolation and soldering the tracks.
Then there could be discoloration on the reference patch.
Also I use to lift the front of the scanner rails with shims to bring the scanner closer to the glass with about 1mm that helped a lot.
Would recommend trying that. Shim it with paper on the far side its got a shaft and the near side an angle rail. Just raise that a little.
Forgot about that.
Lucky i don't have to struggle with these machines any more.
Sure they should have released firmware by now that will stop the lamp from running all the time...
