View Full Version : Firmware Bizhub C3110
picquep
01-19-2021, 10:18 AM
Hi, I'm having issues while trying to print from a computer on the Konica Minolta Bizhub C3110, with some computers it will work fine and some don't, all usic the same driver, i guess it is an issue due to the firmware that is old... I have not been able to find the actual firmware to update the machine so I'm looking for it over here.. Does someone have it to share ? email : paul-nonna@hotmail.com
Thanks in advance, i hope you were able to understand me because english is not my native language...
copier tech
01-19-2021, 10:45 AM
email sent.
Firmware Update - Printer & Copier Firmware (http://www.copierfirmware.co.uk)
Me_vs_C3110
04-24-2021, 05:38 PM
Hello all,
I am in search of a place to get hard line tech info on my enemy the KM C3110
The Battle currently being fought
Dose Firmware address the need for SMB v2 or SMB v3? My end game is to move my scan share folder to my TrueNAS server.
Thus far all I get back is TX Failed Send which points to a SMB Type Mismatch...in testing on Win 10 pro I turn on SMB v1 and Win Updates turns it back off ..repeat..
She eats Full 6K toner boxes in very short order as well will make a new post for that ...Looking for best thread to add that to?
My Enemy Collected Intel
Controller F/W A6DT30G0C02-999
Engine F/W A6DT0Y00050G001200
Boot F/W A6DT99G0100-999
Panel F/W A6DT20G0100-999
Fax F/W Uninstalled
Scanner F/W A6DT23G0402-999
Action Plan:
Find Intel about firmware <<< This Post
Collect The Fixed F/W and Tools Needed to installing <<<Step Two
Build Post about putting her on a diet <<<Coming Soon
If above gets done get her some memory and maybe a HDD
Thanks in advance for any input that helps complete the mission,
WillieCee aka Me
Synthohol
04-24-2021, 05:56 PM
SMB version 2.0 is now supported with the following firmware release.
Install Controller firmware A6DT30G0C02-9AV or newer
After installing firmware the following functionality will be available.
Software switch 219 Bit2 can be set to the following
0 = SMB1.0/2.0 Default
1 = SMB2.0 only
copier tech
04-24-2021, 06:14 PM
Hello all,
Fax F/W Uninstalled
Action Plan:
WillieCee aka Me
Happy to help with this special firmware.
We can supply most major manufacturers printer & photocopier firmware. Click Here To Download - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware (http://www.copierfirmware.co.uk).
Synthohol
04-24-2021, 06:30 PM
i sent him a PM as well :)
Me_vs_C3110
04-25-2021, 11:41 PM
After just a light learning curve on my part to get the file in the printer and reboot her up and just like that everything start working as expected.
For that I thank you Synthohol
For the life of me it seems like KM could make that intel little easier for Technically minded User to find and shame on Goo&Tube for showing me everything but 3 lines of text.
I have a Pdf that would complement those two firmware file if you would like it for your archive.
EOD:
KMC3110 Scan share now lives on TrueNAS-12.0-U3
Thank You again ,....
MasterT
01-27-2023, 01:54 PM
I need latest firmware for Konica Minolta C3110.
What I have now is this:
ROM Version
Controller ROM Version A6DT30G0803-999
Engine ROM Version A6DT0Y00050G001200
Boot ROM Version A6DT99G0100-999
Panel ROM Version A6DT20G0100-999
Scanner ROM Version A6DT23G0402-999
Fax Board ROM Version -
If anyone can help please let me know.
I wrote to copier tech (https://www.copytechnet.com/forums/members/copier-tech.html) in forum private and email but no answer.
copier tech
01-27-2023, 04:50 PM
ROM Version
Message received & firmware sent, thanks for your support.
keszel
02-25-2023, 08:31 AM
Hello.
Please send me the latest bizhub C3110 firmware. My email keszel1974@gmail.com or PM .Thank you
copier tech
02-27-2023, 07:45 PM
Hello.
Happy to help. Please drop us an email at either link below.
Dereckachy
06-21-2023, 01:00 PM
Hi Please I need latest firmware for Konica Minolta Bizhub c3110. My email — frederickagubuzu@gmail.com
copier tech
06-21-2023, 03:48 PM
dimoo0
11-18-2023, 10:46 PM
elshenawyy@yahoo.com
copier tech
11-19-2023, 10:32 AM
devset
01-11-2024, 05:45 AM
aslesarev69@gmail.com
Thanks!
copier tech
01-11-2024, 07:46 AM
Thanks!
See my posts above :cool:
