View Full Version : Bizhub C224e grainy image quality problem
Sandoval
01-30-2021, 05:16 PM
Hello,
I have the quality problem on my bizhub C224e. Check the photos. There is a grainy image.
I have already replaced the belt and black drum with brand new ones. Used only original toners. Counters B: 230 000 C:46 000.
Any suggestions?
4809448095
Phil B.
01-30-2021, 05:24 PM
Hello,
Any suggestions?
4809448095
the dev units are being depleted.... you need to replace dev power/frames
Sandoval
01-30-2021, 05:33 PM
All dev units or black only? As the color counter is 46000.
allan
01-30-2021, 05:38 PM
Please post half tones at 125 and use test chart prints.
Could be moisture in developer... But also can be a thousand other things.
blackcat4866
01-30-2021, 05:39 PM
+1 on that. If you were to use an image with separate base colors we could tell which colors are affected ... like this:
tsbservice
01-30-2021, 06:47 PM
Are you a tech or enduser? Do you have manul?
Phil B.
01-30-2021, 08:23 PM
damn sure can't tell from his SPARSE profile...
my guess? END USER or maybe a green tech... we covered this problem in Copiers 001.
Sandoval
02-01-2021, 04:28 AM
Hello,
I'm service technician and I have manual, but never seen such a problem.
tsbservice
02-01-2021, 07:13 AM
Hello,
Then where are CMYK halftones or use charts BC provided and post samples.
Hello,
It could also be a paper problem.
